Meteorite Damascus
Gary Mulkey
I didn't get in much shop time  today but did manage to get the first of  eight dogwood flowers roughed out.  These will all get inlaid side-by-side into a billet of 1084 using a canoe & 1084 powder.
IMG_4824_opt
IMG_4830_opt
  • Like 8
Gary
ABS,CKCA,ABKA,KGA
OK. Now you are just being a show off. :lol:
Keep going man!
  • Haha 1
B)   !!!!!!!!!!!!!
If ya can't be good don't git caught  !!                                        People who say stuff can't be done need to
        git the hell outta the way of people who do stuff   !!!
Show me a man who is called an expert by his peers
And I will show you a good man to listen to ......
Show me a man who calls himself an expert
and I will show you an egotistical asshole...............!!
I got the remainder of  the flowers shaped & ready for welding today.  I hope that these pics explain my process.
IMG_4841_opt
IMG_4844_opt
IMG_4849_opt
IMG_4855_opt
I'm going to  take some time off from the shop for a while.  I'll try to keep  you updated in a week or so as I progress with this one.
  • Like 6
Gary
ABS,CKCA,ABKA,KGA
After taking a week off for a  small vacation, I'm back in the shop.  I got this billet  welded this morning.  Unfortunately the second flower didn't weld to  my satisfaction so I shortened the billet to  five flowers.  That still  gives me plenty of  steel for a  good  sized  blade though.  Here's a look at it after a rough grind and a quick etch:
IMG_4877_opt
I'm thinking of using blackwood for the handle with an inlay of this mastodon ivory cut into a  scroll pattern.
IMG_4863_opt
Edited by Gary Mulkey
  • Like 3
  • Thanks 2
Gary
ABS,CKCA,ABKA,KGA
Here's the blade after being forged, rough ground and a quick etch.  While forging I found that the flower next to the one which hadn't welded didn't fully weld either so my blade now has a four flower pattern.  Obviously that part of the canoe didn't soak at welding temperature long enough.  It appeared  to be hot enough but sometimes it's just hard to tell.  It still gave me 7 1/2" of blade though which is plenty.  Actually I  think  that I like the pattern better with four inlays than I did with more.  Anyway, it's much better to find these things out early rather than later when you can't work  around them.;)
IMG_4893_opt
  • Like 6
Gary
ABS,CKCA,ABKA,KGA
Starting with the hilt:  Here's my original rough concept of what I want for the handle.  It will be made of blackwood with mastodon ivory inlays and 416 fittings.
IMG_4894_opt
Gary
ABS,CKCA,ABKA,KGA
Nice.  I wasn't sure how that tip flower was going to look once the tip was forged out, but it's definitely a win.
I'll be holding my breath while you cut out those inlays ;)
-Brian
Another soda an more popcorn, this is one hella good show  !!!
Hurry! Brian's turning blue! [Ivory smokes as Gary's jeweler's saw shreaks and twangs like the bow of a mad fiddler]
 Seriously cool stuff Gary! This is my favorite so far. Ancient, but timeless.
  • Haha 1
Getting ready to cut the ivory inlays:
For once I ground off  the bark on these mastodon scales for a couple of reasons.  One I wanted more contrast in color with the blackwood and two I wanted a flat surface on which to glue the paper pattern--
IMG_4906_opt
Here's the pattern cut out of cardboard--
IMG_4911_opt
IMG_4912_opt
The pattern transferred to paper & reversed.  These will get cut out & glued directly onto the ivory.  It's still slightly crude at this point but I  will correct that when sawing out  the inlays.  [Each sharp point of the scroll will get a small silver pin inlaid there for effect.]  These scales will eventually be part of a frame tang handle.  I haven't decided for sure but will probably add a little  filework to the frame.
IMG_4915_opt
Gary
ABS,CKCA,ABKA,KGA
I got delayed a bit on this one as my old  scroll saw that I  have  used for cutting  out inlays for years finally died so while I wait on a new one  to be delivered I got started  on making a  guard for  this one.
IMG_4916_opt
Since I  forged the center of guard I'm having to  anneal it before cutting the tang slot.  Once the slot is  cut, I will profile the ball-tip guard and bend it into an "S".
IMG_4922_opt
Gary
ABS,CKCA,ABKA,KGA
4 hours ago, Alan Longmire said:
What kind of lathe is that, Gary?  The flat ways and what I can see of the saddle look like my Atlas/Craftsman 101.
It's just a cheap Taiwan mini lathe that I added an external  1hp motor to as it was underpowered.
Gary
ABS,CKCA,ABKA,KGA
I'm limited on what I  can do on this project until my new saw for cutting the inlays gets delivered but did manage to get the guard profiled, slotted, bent  & sanded today as well as the blade H/T'ed & tempered.:
IMG_4974_opt
  • Like 5
Gary
ABS,CKCA,ABKA,KGA
I finally got my new scroll saw in and got the inlays done.  While playing with the new saw, I wasn't satisfied with the first three attempts at inlays and ended up using some walnut burl with Arvorin for the inlays.  [If you're not familiar with Arvorin, it's the Cadillac of faux ivory.]
These inlays are far from perfect and definitely show that they were cut by hand but after I scrimshaw them I believe that they'll serve the purpose.
IMG_4979_opt
  • Like 3
Gary
ABS,CKCA,ABKA,KGA
