First Damascus Knife
My first attempt at multi layer Damascus, I chose low layer twist on a modified cleaver.
15 layers of 1084 and 15n20 dry welded by hand and a homemade press with a 20ton air/hydraulic jack. I got down to 1.5” square then cut my end off to check the welds.
I BBQ quite a bit and wanted a cleaver shaped blade to slice with. I welded and forged out a billets my shop, then went to a hammer in hosted by DanGraves to pick his brain and use some of his toys to do the real work. Handle is Buckeye Burl that I picked up at the Arkansas Knife Show. OAL is just shy of 14” and a cutting edge of 8.5”. I made some mistakes along the way but am pleased with where I ended up. IIRC this is knife 21 for me.
It sliced a brisket and ham Easter Sunday like a champ.
  • Like 4
Sadly yes, sort of. The pin hole was drilled in the tang correctly but I gouged the scales and had to grind out quite a bit of material under the front pin.
Also had some etching issues, my typical jar wouldn’t accommodate the knife so I foolishly tried to insert and etch then flip and etch the other side which resulted in a pretty substantial overlap line. I cleaned it up but not as good as I should have. I ended up pouring my etchant in a shallow pan and laid the blade down in it which worked but I should have had a better plan.
Im thinking about trying some aluminum black on the pins I don’t like the way they clash.
