Jan Ysselstein
Blade straightening after quench before tempering
Normally I straighten blades after tempering...I just read an instruction by a blade smith suggesting the blade is easy to straighten just after a differential quench to about 450 F ( quench oil temperature  at 450 F and a clayed spine and back of the blade...W-2, 203- E damascus . Doe anyone here use that type of a process?)
Claying the spine will allow the formation of pearlite on the back of the blade which will be easier to straighten but the edge will still form martensite so you will have to straighten the blade before the conversion descends to near the Mf point.  It can be done but you timing has to be right.
It can be done on any blade when it is between Ms start and Ms finish.  Quench past 900 degrees F fast enough to beat the nose of the TTT curve and then you have until it gets to around 450 F to tweak it.  There is no time limit, just temperature.
this is why I have a large vice with aluminum plates set up right next to the quench tank
Aluminium plates seems like a good idea to me because, according to what I have read, if the blade cools too slowly from MS start to finish it may auto temper the martensite and you end up with poor hardness. Is that right Alan?
Thanks for the rep
lies guys...I like the idea of quenching quickly past the nose..my tendency to fumble makes me want to stay with tempering.
When quenching long blades I clamp them between two heavy pieces of square tubing, this seems to press out any small warps.
on a 6mm thick blade I seem to have enough time to fumble with the clamps, I haven´t broken a blade yet with this method.
I'm not Alan, but yes, you can indeed auto-temper, but your martensite generally isn't starting to form much above your final temper temperature, and you aren't staying that hot too long anyway.  But it is possible you won't see peak hardnesses.  B)
And generally Ms= martensite start, Mf = Martensite finish, and M90 is 90% completion.  So what we are really shooting for is straightening between the nose of the curve and Ms.
What Jerrod said! :P
