Garry Keown Posted June 13, 2019 Posted June 13, 2019 Soon after I started making knives I made a edge scriber but was having to keep adjusting it for the various thickness of blades I have been using so over the last week I set out to make another two in between doing other things. I cut a couple of lengths from an old farm implement shaft After giving them a clean up they needed a flat ground down the length of them with a hole drilled and tapped for a 1/4 inch bolt and a 3/8 hole drilled for the scriber shaft A couple of 3/8 bolts and a concrete nail are the other parts needed. Bots are cut to length and a flat grond down the length for the locking bolt to seat on and a hole for the scribe pin The scribe pins cut (and sharpened) from the concrete nail And assembled ready to go with one for the .125,(1084 and 12C27) .156 (1095) and .170 (1075 steel I most often use. 3 Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing.
Gerhard Gerber Posted June 13, 2019 Posted June 13, 2019 Three, maybe four years I've been meaning to make something similar to what my mentor did.......and I'm still using drill bits If I understand correctly you place the flat of the blade on the flat of the tool and then scribe? Interesting, different approach to the few I've seen.
Garry Keown Posted June 13, 2019 Author Posted June 13, 2019 8 hours ago, Gerhard Gerber said: Three, maybe four years I've been meaning to make something similar to what my mentor did.......and I'm still using drill bits If I understand correctly you place the flat of the blade on the flat of the tool and then scribe? Interesting, different approach to the few I've seen. Yes that is how they work. Simple but very effective and cheap to make so having one each for each thckness of material we use is very efficient. I usually have the blade in the vice to file in the sharpening notch and mark them then. 1 Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing.
Charles dP Posted June 15, 2019 Posted June 15, 2019 Thanks Garry. I’ve also been meaning to make one. I like your design and will have to ‘borrow’ it "The way we win matters" (Ender Wiggins) Orson Scott Card Nos qui libertate donati nescimus quid constat
Garry Keown Posted June 15, 2019 Author Posted June 15, 2019 12 minutes ago, Charles du Preez said: Thanks Garry. I’ve also been meaning to make one. I like your design and will have to ‘borrow’ it An 1 1/2 inch square block would be just as effective Charles. I had the round bar so used that, besides the round feels good in hand. 1 Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing.
Connor Lyons Posted June 18, 2019 Posted June 18, 2019 Pretty slick little scribe! Could you describe a bit how you calibrate/adjust these to match the centers of the various thicknesses? With the scribes ive made that has been the most challenging part, it takes a good while of fumbling around for me to get it close.
Garry Keown Posted June 19, 2019 Author Posted June 19, 2019 (edited) 8 hours ago, Connor Lyons said: Pretty slick little scribe! Could you describe a bit how you calibrate/adjust these to match the centers of the various thicknesses? With the scribes ive made that has been the most challenging part, it takes a good while of fumbling around for me to get it close. I hold it onto the blade and lightly set the locking screw and mark from both sides hoping for the marks to be about 35thou apart (for pre heat treat grinding) and then it is a simple tap with the handle of the small spanner if it needs correcting before tightening the lock screw. With one for each steel thickness it is set and forget. Edited June 19, 2019 by Garry Keown Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing.
Cal G Posted July 27, 2020 Posted July 27, 2020 Here are my edge scribes. A piece of nylon with a bent piece of music wire (hardened ) . It is fully adjustable from zero to 1/4 inch blades. The other scribe I make is for hollow grinding height or it can be used to scribe a line for multiple pin placement on a handle. 1
KenH Posted September 6, 2020 Posted September 6, 2020 That's a neat idea using concrete nails for scribes. I expect concrete nails are really hard and will hold the point nicely. Thanks for the idea. Ken H> 1
Geoff Keyes Posted September 6, 2020 Posted September 6, 2020 They do make replaceable carbide scribe tips, like these https://hamptonresearch.com/product-Tungsten-Carbide-Scribe-Glass-Cutter-with-Replaceable-Tips-657.html "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver
Garry Keown Posted September 6, 2020 Author Posted September 6, 2020 1 hour ago, Geoff Keyes said: They do make replaceable carbide scribe tips, like these https://hamptonresearch.com/product-Tungsten-Carbide-Scribe-Glass-Cutter-with-Replaceable-Tips-657.html Was looking at something similar but having concrete nails in the draw it was a simple solution and has worked for a number of years on the first one and the other pair are also doing great service. 1 Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing.
Don Abbott Posted September 10, 2020 Posted September 10, 2020 Are you just driving the concrete nails in for a friction fit? 1
Garry Keown Posted September 10, 2020 Author Posted September 10, 2020 2 hours ago, Don Abbott said: Are you just driving the concrete nails in for a friction fit? Yes. There is not that much pressure against the point and that is light sideways pressure as it is used so the tight friction fit has been sufficient for all that I have done Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing.
