Feather Kitchen knife.
I have been playing with feather patterns recently, started up looking at illerup idal blade fern patterns and later evolved to a feather pattern , trying to get a stand alone feather...Its been fun. and has lots of spin offs running in my mind. firy , flamy frondy stuff!
  • Like 7
(Picks jaw up from floor) Now THAT is cool! It's not easy to absolutely gobsmack me with a damascus pattern, but this one did.  It's just so clean!  And while I think I know sort of how you did it, I'm not entirely sure...  that hasn't happened in a long time!
Plus it's pretty...
Plus it's pretty...
 Thanks Alan. pretty is the idea (and part of the function!).
thats the cool part of this , lots of ways of coming out  with a different take on stuff...I have a few other ideas brewing at the mo that I hope will be more gobsmacking! things taken from other places applied to standard stuff...we shall see! I also have hit a few dead ends with very promising but ultimately impossible patterns!
Very cool! What's the steel mix?
Any wisdom to impart on thickness/sharpness of the cutter used to "smear" the feather? Have you noticed that different cutter shapes produce different feather angles/lengths?
Dave
Plus it's pretty...
Alan said it best - holy crap that is sweet!
Dave
I have been using an 8mm radius as the edge. A parallel cutter works better than a wedge, it’s only the cutting edge doing the work. Material thickness and heat when you cut will have a great deal of influence on the final pattern. I’ve only done it 5 times though! So I’m still at the learning stage!
Im going to take a guess, which may be totally incorrect.
The feather part, was part bar steel, and part powdered steel welded in a canister and then split and rewelded.
Regardless of how you made it, that is one SWEET blade, I love the simplicity of the center with the chaos of the outer bars.
no powder in it its much simpler than that .......
One of the coolest patterns i have seen in a while. Very interesting.
