Wrought iron tangs.
Doug Lester
8 hours ago, Emiliano Carrillo said:
show a method for forge welding without wire or tack welds
Can you discuss your methodology for this a little?  Unfortunately I won't be able to attend Ashokan this weekend and I've only done "drop tong", hammer facing, axe bit, and single sided laminate blades (yes, warp city...) forge welding without tacking or wiring first.
15 hours ago, Alan Longmire said:
Emiliano nailed it.  B)
As usual.
On 9/18/2019 at 5:15 AM, Emiliano Carrillo said:
I've held and documented several larger seax blades, all of which had the tell tale signs of a forge welded tang and sandwiched contribution.
I've never seen this on any of the seaxes I've studied. Which seaxes were these?
Jeroen Zuiderwijk
On 9/18/2019 at 4:28 AM, Doug Lester said:
Going back to the seax welding a wrought iron tang on might have been to conserve hardenable steel (if they could tell the difference).  From what I have read some of the blades were basically iron and some had enough carbon in it to be considered steel.  Depending on the sources.
Before patternwelding became common, seaxes were constructed the same way as knives, which just about any combination to have a steel edge and iron body. However, I've never seen a fully steel seax with an iron tang welded onto it myself.
Quote
Watch that video where he compares the seax with the bowie knife.  He explained that the broken back seax come from the British Isles and blades with more of a rounded or spear point come from Frankish or Nordic regions.  That seax that he had he ordered without a handle with the intent of applying one himself.
Rounded spines on seaxes were used simultaneously in Anglo Saxon and Frankish regions. The broken back shape is later, and the reason you mostly see them from the British Isles is because seaxes disappear from the archaeological record in Frankish regions at the time the broken back becomes the common style.
Jeroen Zuiderwijk
Getting into a bit of a tangent here, but any ideas why they went out of style on the continent but not in the Isles?
I don't know, changes in regulations, battle tactics etc. In the Isles you also had seaxes of short size as well as longsaxes, while on the continent there were only longseaxes, which formed part of warriors weapon kits. I suspect that the shorter ones were carried by civilians as personal defence. Something also to keep in mind is that burrying the dead with their weapons stopped around the same time as seaxes disappear from the archaeological record. So there may have been more around then the archaeological record shows. However, swords continu to be found in later periods, while seaxes disappear.
Jeroen Zuiderwijk
Definitely! I was very upset with the lack of pictures in the last book I bought. Very descriptive wording, but still; pictures would be nice... I think he's got plenty of pictures though! He's an international treasure as far as I'm concerned.
I realize now that I've completely derailed this thread... My bad.
On 9/22/2019 at 6:19 AM, Zeb Camper said:
You should write a book, Jeroen!
I suggested that to him already. Sadly, he dismissed the idea.
My guess is battle tactics and interaction with different cultures with different weaponry. One thing that is common across all warring cultures is the appropriation of weapons and tactics from the adversaries. Which would explain Jerrod's question:
It took longer for the isles to get conquered by the forces that spread across the mainland. So, the changes took longer to influence those places.
I'm no scholar by any stretch of the imagination, this is pure conjecture.
Some things to keep in mind, on the mainland (Frankish Empire), seaxes disappear either during or shortly after the reign of Charlemagne (followed by Louis the Pious). In the Isles, they disappear after the Norman conquest. History isn't really my thing though.
And yeah, I don't fancy spending the precious time I have to write a book. I've uploaded most of the photos and documents I have (still in progress of adding more) to the facebook group. So basically if you go there you can quite easily catch up on what I know on the subject.
Jeroen Zuiderwijk
