JohnCenter 1 Posted September 30, 2019 Share Posted September 30, 2019 For those with more experience: Can a 1/8" micarta rod perform as the stop pin for a small friction folder (1/8" blade with 1/8" micarta handle slabs)? Will it stand up to the 'wear and tear'? Link to post Share on other sites
Joshua States 2,573 Posted October 4, 2019 Share Posted October 4, 2019 (edited) I really don't know, but just thinking out loud here for a minute. Micarta is a fairly brittle material and not what I would want either a harder substance, or a blade edge, hitting repeatedly or pressing on, over time. This is why I never peen pins over micarta, I'm afraid it will crack from the pressure, either during the process or from constant pressure over time. Edited October 4, 2019 by Joshua States “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Alan Longmire 3,887 Posted October 4, 2019 Share Posted October 4, 2019 Also just thinking out loud, I think a 1/8" pin is way too small in micarta. A 1/4" pin might stand up better, even though it would look huge. If you already have the 1/8" micarta pin stock, try laying a short piece across a vise open 1/8" wide. Then take you blade material and press down on the pin. I'm betting it snaps pretty easily. It should, since in that test it can flex. Then think about the flexing of the whole thing in use. 1/8" scales are pretty bendy. Link to post Share on other sites
JohnCenter 1 Posted October 9, 2019 Author Share Posted October 9, 2019 Thank you for the responses. Both your concerns are exactly mine. I already had doubts. I guess I will go with the more logical approach of drilling blind holes for the stop pin to achieve the same affect, but with the expected strength. Link to post Share on other sites
