Jan Ysselstein
Question regarding vacuum chambers used in stabilizing wood
When looking at manufactures vacuum chambers ,  i noticed some are labeled not for stabilizing wood. Does anyone know why that is the case. Some mention the cactus juice name specifically.
It may depend on what the chambers are made of.  The chamber itself or attached components may not be chemically compatible with the stabilizing agent.  If the product says not for stabilizing wood, take it as gospel.  I tried to rig may own vacuum chamber with a food vacuum storage jar and food vacuum pump.  The agent that I chose to use ate through the plastic of the jar causing a spill on the floor.
Edited by Doug Lester
Yep, cactus juice will attacks some plastics.  I seem to remember that they have a warning about one plastic in particular on their website.
The one I bought is a large steel container with a perspex lid. Cactus juice can attack perspex apparently but it shouldn't come into contact with the lid. I bought a really large container so that I can put the actual solution and blanks in a second container inside the main tank. This works really well, well I've only used it once so far but I was really glad I bought the big one. I could even stabilise multiple batches at once with two different colours in two containers if I wanted to....
Translation from English to English: Perspex (trade name) = Plexiglass (trade name) = acrylic (generic name).
IN
Interesting, I never knew that!
So what type of see through lid is best for the stainless steel chamber as the one I have is sometimes difficult to see through. I have had to sand it off a couple of times.
I'm using a piece of 1/4" polycarbonate supported by a piece of 11 ga. stainless as the lid on my chamber.  I can't really speak for the longevity of it yet, but its crystal clear and easy to see whether on not the pieces are done bubbling.
What dia is you chamber Alex. Mine is 8 inches so may need something thicker than 1/4 to hold against the vacuum.
Yeah, you'll definitely need something thicker than 1/4", thick glass would definitely work well.  I built a custom stainless steel chamber for stabilizing handle blocks.  The top opening measures 6" x 7" and even with the stainless plate underneath it, the lid visibly sucks in quite a ways at full vacuum.
A good rule of thumb is that a strong vacuum will be 15psi.  Find the surface area of your lid in inches and multiply by 15 to find out how many pounds of force are on it.  It does add up pretty quickly.
Thank you for all the replies here ..interesting stuff. It looks like it will be a 9" diameter SS pot with 3/4 " clear plastic ( poly carbonate or plexiglass ) and a Viton 1/4" seal. BY putting a slight taper on the hole in the plastic the 3/8 pipe thread can just be inserted as if the plastic were threaded.
Jan
@owen bush
This is the kit I got from amazon in the UK. As mentioned on the phone, I would get a pot that was the same diameter, or bigger (this ones 25 cms), but deeper if I was to buy again, so I did not need to monitor the foaming for the 1st 10 mins of vacuum. Pump and tank were about £230 all in, and the US (baby) gallon of juice was £100 ish.
The blanks go in the cut down swarfega tubs in the resin (3rd pic). The resin is not directly in the chamber.
The lid of the tank is glass, pretty chunky thickness.
I have been told that a 2 stage pump is not necessary since I bought mine, but it was not much more expensive in the overall scheme of life. Ive left the pump running unattended for 20hrs plus, and it did not smoke it.
There are some merits to stabilising the handle blanks, some people do crazy things to handmade knives, like putting them through the dishwasher etc :wacko: :D
A couple of pics of wood I have stabalised in the kit shown above. I got the wood pieces from a slightly hippy chap on Bridport market in Dorset, who has all kinds of interesting bits and pieces, after I had chopped it up it worked out at about £0.60 a block. ($1 usd ish) The juice consumption is looking at being less than £2.00 a block, so its not an expensive process all things considered. This is only my second run with the kit, so take anything I say as if you are listening to an enthusiastic newby!
Fist pic is the timber as bought (very punky, but pretty), second pic is stabalised, with one of them shone up as a 'vanity etch' ! I also stabalised some bog oak blanks this time to use as ferrules' with the beech, should help prevent differential movement in the finished handles.
Daft as it might sound, home stabalising gives a bit of creativity to the handle process as well, as you can choose the cuts on the wood.
