A small edc/bushcrafter from old file steel. Overall knife size is 7.25 inches. 3.25 inch blade and 4 inch handle. Edge quenched in water. I had this different handle style in mind for a while and finally got around to making it.It has a full tang upto the brass disc on the handle.The front part of the tang is covered by a brass shim collar and has teak wood scales fixed by pins .The remaining part of the tang goes through the wood and is peened over a brass endcap.
  • Like 3
I must say I've never seen a handle made that way.  Interesting look!
Thanks a lot Alan. Ya even I thought  I had never seen a knife with a handle made like this and it would be unique...so I went ahead and gave it a try. If you like the look of it then it has worked out well :)
I am working on another one in the same style.This time around I will use a quarter inch diameter brass pipe which will be flattened and shaped to make the collar.
Very interesting indeed, and it works. On the next one, you may want to make the handle a smidge longer... 4" is just almost too short for me (personally). And I think it would help with some of the dimensional proportions. Definitely a cool idea.
I like it. Look forward to seeing how it evolves in your next one.
Thank you Cason and Rob. Actually I wanted to keep the length for this knife around 7 inches overall. It fits my hand smugly . I agree though that for someone with bigger hands it might be a little small. For the next one I am plan to keep the blade width at 1 inch which might make the dimensional proportions better.
That is a cool handle construction!
Made some progress on the blade for the second knife. Blade has been forged close to shape and the shoulders filed.I thought of making the front area of the handle a little more well defined by adding a guard. A rough sketch of what the knife should look like. Now let's see how close I can get to the sketch. Found a nice piece of rosewood lying around which will be used for the front scales and at the end of the handle.
