Ross Vosloo
First sword, let's go for broke... RAPIER WIP
Hi all,
So, I'm about 2 and half years down the rabbit hole with a fair amount of knives made. So it's about time to embark in my first sword.
Not being the type to walk before running, I thought about what sword I would really like to make, not about what sword I could actually make. Walking is over rated anyways.
So here's the plan. I'm bang on six feet tall, and according to research, a rapier wants to come up to your belly button. On me, that's 110cm overall length.
I'm starting with 12mm round 1070 steel. After the first round of forging I have a preform that's up to length, and consistently about 20mm wide and 4-5mm thick across its length. I've yet to forge in some distal taper.
So here is my first question to you guys: rapier width. Is 20mm across wide enough?
Picture time
12mm round 1070 in the forge
After about 50% of preform done
About 90% done
Complete preform
This last pic is my idea of how the swept hilt will look. Long ways from this yet, but always good to have a plan, right?
So, thoughts? I will keep this thread updated as I go, but always nice to have input from those who have walked the path before... well, run the path :D
Best of luck and love your handle drawing. Look forward to seeing your progress.
20mm wide by 5mm thick at the ricasso is within the range of historic rapiers, but a little on the wimpy side.  They tend to be quite stout at the hilt, like 25mm wide by 6 to 7mm thick, expanding to 30-35mm when the bevels start.  Distal taper varies, but it's never linear.
That said, the one Reichswert (a sort of sword-hilted rapier thingy popular in the southern German states) I have made was about your dimensions, though, and it handled like a dream.  Go for it!  B)  Forging them is easy, finishing them is another level of fun. ;)
Here's my one long pointy one prior to adding the grip and pommel, 44" equals 111 mm cm (edited 'cause I goofed!):
and the grip:
I can't wait to see how you do with one!
Edited by Alan Longmire
Definitely watching this one.
1 hour ago, Clifford Brewer said:
I was just about to grab the popcorn for ya, looks like you got  it first! :lol::P
  • Haha 1
Popcorn And Drink animated emoticon   .... and a beer to go along with the popcorn... looking forward to the next installment of this build
  • Haha 1
Thank you very much.
Thanks for the awesome info  and awesome rapier. I hope mine comes out half as good as yours.
On 11/6/2019 at 7:38 PM, Brian Dougherty said:
Good luck Ross!  I'll be following along.
Thanks guys! Never had people following along before! :D
Right, update time.
Today marked a big day for me in the forge welding area again, this time cable Damascus.
So what does this have to do with rapiers? Hold your horses, ok getting to that.
First though, some details about this blade as I forged it out as practice for what I'm going to do with the rapier.
I started out by forge welding 3 peices of 25mm cable about 8" long into billets. I then took all three billets and forged them into one billet and squared that up.
This was the main part of my experiment done. I now know that not only can I forge weld the cable to what i need, but that it will give the look i want.
Here is a couple of pics of forging the blade and heat treat.
So what's my plan and what does a cable Damascus knife have to do with it? I'll show you...
So here is the plan. Currently, mu rapier blade is a little on the week side. Too thin and not enough thickness.
Plus, seeing as we are going all out on this, I wanted to up the anti.
the diagram shows my plan. I'm going to forge out 2 billets of cable Damascus and then forge weld them to my blade, effectively creating a San mai.
This will give me both the steel for the width and the steel for the thickness, plus the degree of challenge I'm stupidly looking for, and of course, if it all comes out ok, it should look pretty awesome too.
Any thoughts from those more experienced?
That will look pretty awesome!  Just be very careful to keep the welded cable the same thickness from one side to the other lest you spend more time fixing warps than the initial forging.  Oh, and you may want to bevel the edges of the cable a bit to lessen the chance of cold shuts. Trapezoids instead of rectangles, in other words.
Been a while since I have had a chance to work on the rapier. My last plan to forge weld cable Damascus to the already forged out 1070 blade is not going to work, for a couple of reasons.
One, I dont have enough cable. And two, well, I dont trust my abilities to pull off that forge weld yet. So that 1070 blade will get turned into a small sword. It's perfectly dimensioned for that already.
Onto the rapier. Yes, I'm still making a rapier. A mild steel san mai rapier :D I'm a sucker for punishment.
What you see here is my billet all welded up. 2 layers of 1070 side by side and then a layer of mild steel either side. I welded up everything to try and prevent any oxygen from getting in because I knew that I could not heat the entire thing at once to forge welding temps... forge is too small.
Here is the entire billet after setting the welds. Felt good and solid, you can really feel when it starts to firm up under the hammer
And success!!
I just etched the end of the billet, but I ground out all the welds along its entire length, both sides and all the welds look good.
So I have since started drawing out the blade  I'm about 30% done and will pick it up again tomorrow
Edited by Ross Vosloo
I was wondering what was happening with this project.  Slow and steady!
Ja, been a busy couple of months. But I finally finished all my back orders and now have some time to work on my own projects, so full steam ahead
How did I miss this?? :blink:
Ross, you are adding to you bag of tricks very quickly, well done.......watching with interest B)
Haha, no idea bru. Thanks very much.
So here's where I am right now.
Pretty much have the blade forged out to profile. It's at pretty much the perfect length, with the tip on the floor the end of the tang gets up to my belly button.
As for width, I have 30mm at the start of the blade tapering right down to 12mm. I think that's going to do it nicely.
Now I have to put this blade on a diet. It's at 1.2kg now, and my final finished sword weight is 1kg. So I'm thinking I need to get the blade alone down to around 600grams. Any one have any Thoughts or experiences on weight of the blade when finished ground?
Anywhere between 600-900g can work there. The hilt won't be very heavy, and you use the pommel to adjust the balance.
That said, an unmounted blade should still feel "right," in that the nodes of vibration are controlled more by the blade geometry than the weight.
To tune it once you're well into the grind, clamp a small weight to the end of the tang. This weight is pretending to be the whole hilt, not just the pommel, so keep that in mind. When you hit the right weight it will feel like it's floating in your hand. When it does that, you should be able to hold the point still in space while moving the hilt all over the place.
I should make some more rapier blades, tuning them is great fun...
