Pieter-Paul Derks
The Mortlake Giant WIP
I am currently working on something that I think the people on this forum will enjoy: A huge longseax loosely based on a find from the Thames at Mortlake, although I am not really trying to make an accurate copy.
 This beastie is forged from agricultural spring steel, I might do a "Proper" multibar Damascus version in the future.
 It is 105 cm overall length and weighs almost 1500 grams before fullering and fine grinding.
Obviously I was inspired by the many excellent seax threads in the history subforum, I can't believe some of those are almost 10 years old, Those are the threads got me hooked to this forum as a 14 year old.
I am not totally happy about the profile yet; I think I must make the point a bit longer, but I am open for any suggestions.
It is heat treated and I’ve done a fair amount of grinding, the next thing will be grinding/scraping some fullers.
I also have a question about distal taper on these very big seaxes. My version tapers from 11 to 5mm at the break, because of a cold shut in the steel near the tip. Are the originals of this size distal tapered like this? Or do they maintain the 10mm thickness all the way to the break like smaller seaxes?
The Inspiration: number 4 on the picture
As forged:
The almost obligatory menacing selfie with a big blade
My (t)rusty heat treating setup.
Where I am now, heat treated and ready for fullering.
Looks good!  I agree the tip may need a little length.
I have not seen the Mortlake in person, but the bigger ones I have seen (Sittingbourne, Battersea, others in the British Museum and the Museum of London) have no taper.
I haven't seen any originals of this size close up and only maker later period swords but from a sword-making point of view, I think that at this length, without distal taper it would handle about as well as a crowbar. I wouldn't mind the distal taper you have. It will still be a very blade-positive chopper.
Edited by Lukas MG
Looking good and interested to see more.
This is my opinion as well, after swinging the blade around a bit. It actually handles quite nicely and still hits with brute force.
My plan is to fit a very long handle, and I think it will truly be a fearsome weapon then.
My guess is that these really big seaxes were mostly meant for short duels, rather than real battlefield use.(spears are better for open batlle anyway.)
but in a 5 minute duel, a 3 or 4 pound blade would be effective and I really wouldn't want to be the guy on the recieving end in such a situation.
I think I might make the next one with less taper and see how it handles.
 I wish I knew a guy in the museums, holding an original seax would answer a lot of questions I have about handling.
You're not too far from Jeroen, and he has an impressive set of reproductions of documented specimens.  Assuming he'd let you play with them, of course.
Here's the spine of the Battersea seax, #6 in your picture.  Sorry I couldn't get any more directly above it, that case is rather tall.
It's a little hard to tell from the picture but the Battersea Seax looks really thick at the spine and it seems not to have much or any taper to it.
Yes.  It's about 3/8" / 8mm and has no taper at all.
That battersea seax is real beauty too, the thick spines are one of my favourite things on seaxes, a shame that they are so hard to see in the museums.
I might indeed take up contact with Jeroen one day, I am also really interested in his bronzecasting work.
When I go to London next year ( Owens hammer-in B)) I might need to spend a few extra days there and visit some of the museums again.
And it's very convex, so much so that the spine is actually thinner then the middle of the blade. It weighs 1138 gram, which is a lot for such a relatively short blade.  The Heusden seax which I reproduced is a more flat grind, and 7mm at the spine. Otherwise the dimensions are comparable.  But my reproduction of that one only weighs 680grams including the hilt. So the profile of the section matters a lot. The original has a fuller and grooves, so would have been even lighter.
With these seaxes, mind that a lot of the weight distribution is achieved by the very long tip. Eventhough the spine might be without distal taper, it's only about 2/3 of the blade length, after which both the thickness and with of the blade taper to the point.
I did a lot of grinding and fuller scraping last week and I have a lot of hand polishing in my future.
I just thought it would be fun  to give a quick update.
I tweaked the profile and it looks a lot better now, and I have also scraped in 3 fullers, two on the face and a single centered one of the other side.
The whole blade is ground convex to the edge, something that I see on historical seaxes but rarely on reproductions.
The only real problem I have with this blade is that it is rather soft, In hindsight it would probaly have been better to water quench this steel (probably 1045 equivalent.)
On the other hand I think it is still within historical hardness range and the blade flexes fine and cuts soft targets without damage.
This is the first time that I fullered a long blade, and I am surprised how much stiffer it makes it, it really doesn't want to flex at all now and would be great at thrusting through light armor.IMG_20191201_163822.jpgIMG_20191201_163925.jpg
Cool. That thing is a beast. Cant wait to see it finished.
So I did get a lot further on this project.
I just took my time with all the hand sanding, almost three feet of blade with three fullers apparently takes a while to sand up to 400 grit.:P
I even had to start at 80 grit, because I cant get nice convex bevels on my grinder.
I finished the blade with scotchbrite pads, it was the first time I used it and I am wondering why it took me so long to use this stuff.
The finish is a lot nicer than just plain sandpaper.
After sanding it was time for handle work, here the problem was that I don't have any hardwood blocks that are long enough (40cm:blink:)
I did however have an old oak coat rack stowed away somewhere, so it was recycling time.
Of course there were nails and woodworm holes I had to fix, but in the end I did end up with a very nice handle.
I am thinking of doing a cord or wire wrap to reinforce the front of the handle, as the wood gets quite thin in places.
or maybe even thin leather or rayskin?
I need to get some in hand shots and a cutting video, this thing as an absolute beast.
  • Like 4
Looking great!
That is looking great. Looking forward to the in hand shots.
That looks like a real leg biter.
How on Earth did I miss this? Looking great Pieter.
Thanks guys!
I got a quick selfie(:rolleyes:) so you can see the scale a bit better.
This also is the only picture where the fullers are a bit visible, even at a satin finish they are too reflective for my camera skills.
  • Like 4
Nice!
Now that is a great blade. Love the fullers
Everyone's making some awesome blades here lately! Awesome man! Sheath next?
Dang.  I want one.   Great Work!
Edited by Bruno
Thanks everyone!
I'm not sure if I'm going for a sheath, it would take a significant piece of leather, and I'm all out of money at the moment.
It took a while, because I had some other knives to make and sell, but I finished the handle, I might add some ring dots later if I can find the tool I made for that somewhere.
I think this blade really needed some form of reinforcement at the front of the handle to keep it from splitting, after a few tries with different cord and metal wire I settled on a very simple leather string wrap.
with the leather glued in place it feels really solid and I think it really fits the more sober look of this piece.
After some research I do think that a leather and cord covering would be more historical for this style of knife/sword, and that the partial wrap is more of a scandinavian thing.
There will be a patternwelded one in the future though, so I'll do a different more fancy handle on that one.
This blade is a phenomenal cutter, I want to get some tatami mats to test it properly, as my normal targets like water bottles and cardboard tubes were no resistance at all.
The overall lenght is 123 cm (48 inches) and it weighs just under three pounds, the originals would have been even heavier, but I was limited by the size of available steel.
(at this point I'd consider trading a kidney for a source of 3/8ths 80crv2 <_<)
The cat is for scale ofcourse :D
  • Like 5
