Gerhard Gerber 337 Posted December 4, 2019 Share Posted December 4, 2019 My best micarta is made from wool material I bought on impulse, it's green and easy to get spectacular results, but less polished the grip is amazing....and it's wool, all natural an what not. This is the only woolen material I ever found, so a while ago I go the idea to just buy wool. My usual material shop only had fake wool, apart from (very expensive) "brushed kid mohair wool" Pondered for several months how to use it, then hand an idea. I needed a bolster for a carving knife, started by winding up wool on the tang until I was sure there was enough for the bolster. Use 4 pieces of wood clamped in roughly the right place, mixed up some resin, dumped the wool in there and started winding it on between the "guides" I put one layer of masking tape on the blade so when the resin had set I could tap off the fitted bolster to shape it. Some black tint mixed with the epoxy completely hides the gap between the bolster and the blade. Bonus is the mohair micarta has even better grip, right where you need it. 1 Link to post Share on other sites
Alan Longmire 2,634 Posted December 4, 2019 Share Posted December 4, 2019 That's pretty genius, Gerhard! I must steal that idea one of these days, if I remember to... 1 Link to post Share on other sites
Rob Toneguzzo 773 Posted December 4, 2019 Share Posted December 4, 2019 Wonderful idea and it really looks classy too. 1 Link to post Share on other sites
Conner Michaux 271 Posted December 5, 2019 Share Posted December 5, 2019 (edited) That’s a great idea, I’m definitely going to try that, if you don’t mind. Edited December 5, 2019 by Conner Michaux 1 Link to post Share on other sites
Gerhard Gerber 337 Posted December 5, 2019 Author Share Posted December 5, 2019 Thank you all and you are more than welcome to do the same Link to post Share on other sites
Will Wilcox 262 Posted December 5, 2019 Share Posted December 5, 2019 That's actually a really good idea, Gerhard. 1 Link to post Share on other sites
dragoncutlery 45 Posted December 5, 2019 Share Posted December 5, 2019 you can also do a guard and wrap up under it as you go the attached is what i call confetti micarta its strips of cotton based fabric and was wrapped epoxy wet (so similar ) on to the tang with the pin added later for looks i bagged it up and wood block clamped it to reduce air bubbles and then worked it as normal 2 Link to post Share on other sites
Gerhard Gerber 337 Posted December 6, 2019 Author Share Posted December 6, 2019 Looks good Brandon, will give that a try! I've been making a lot of rolled micarta with everything from linen to hessian, just choose your width, slobber on resin and roll up as tightly as possible. I make them bigger than necessary, wrap in wax paper and apply some pressure to get rid of most gaps. When I want something very tight and "accurate" I've used a loop of wire to catch the inner end of the material, once it's rolled up tight I snip off the ends of the wire and pull them out. 1 Link to post Share on other sites
Rob Toneguzzo 773 Posted December 6, 2019 Share Posted December 6, 2019 9 hours ago, dragoncutlery said: you can also do a guard and wrap up under it as you go the attached is what i call confetti micarta its strips of cotton based fabric and was wrapped epoxy wet (so similar ) on to the tang with the pin added later for looks i bagged it up and wood block clamped it to reduce air bubbles and then worked it as normal This is great too. Going to use these techniques on my next fillet knife. Thanks fellas Link to post Share on other sites
Ross Vosloo 174 Posted December 11, 2019 Share Posted December 11, 2019 thats genius i tell you.... GENIUS!!! i have been looking for options for hidden tang bolsters for thin chefs knives for a while now and i think i just found it 1 Link to post Share on other sites
