New project-States/Weller collaboration
Joshua States
I started a little 3-bar project recently. This is a different situation for me, because I do not have a finished product in mind. I typically create a full scale drawing of what I am going to make and then proceed to build it. This is more of an organic project, as I am thinking along the lines of something I saw in the link in this thread
I started with a 1/2" round bar of wrought iron that I reduced to about 3/8" square. Added a bar of wrought iron/15n20 twist. Then I reduced a short 1" round of W1 down to 3/8' square.
The three bars, next tp the blade shape template.
I surface ground the mating faces.
And tack welded them for forge welding. I left the iron bar long so I would remember which bar was the spine.
Oh there's a plan, just not a very well defined one...….you are correct, this is a no ricasso blade.
Solstice was great. Hope yours was too.
Well, I had to watch Rudolf with Liz, and now I can post the next round of photos. This was today's forging.
I got those bars welded. The result is about 12 inches long (all 3 bars), 1 inch wide and about 1/4" thick.
I roughed in the profile and bevels, & marked the cut for the tang piece.
Finished forging. I still have a little chunk left over for something else. Maybe a puukko sized blade.
It's about 5.75" blade length and 11" oal. 1.25" wide and still pretty stout on the spine.
9 hours ago, Adam Weller said:
Alright... So I think I'm going to make 2020 my official year to learn how to make something like this (even without a power hammer).
Very cool, I can't wait to see the pattern.
The hardest part of making this without a power hammer or press is probably welding up the twist billet. Luckily enough, you do not need a lot of layers for this. I think this twist has 13 layers, but it may be less, like 7 or so. That is fairly easy to accomplish by hand. The welding of the three bars by hand isn't too difficult either. There's a great video in the Arctic Fire 2016 set with Dave Stephens showing the method.
You might get to see the pattern in person some day. It depends on how things turn out...…...:ph34r:
That was my first thought when you said you didn’t have a plan... I will remain hopeful, but no pressure :D
Thanks for the link, I’ve watched all the arctic fire videos multiple times, but I’ll watch that one again before I attempt.
Edited by Adam Weller
Another option could be to start with real thin and narrow stock for your 7-12 layer(ish) stack. You can weld in sections if needed. Would definitely practice on mild steel first, then maybe a scrap of HC. I wish I had done this with my last 2 stacks. Best o' luck all!
Minor progress this afternoon. I forged out a little one from that leftover bit.
I also added a little length to the first one's tang in case a through-tang handle comes into play.
A little surfacing and rough grinding. They are now in the HT oven prepping for hardening and tempering.
Last night I annealed the blades.
The pattern was clearly visible. I may have misremembered the layer count. This looks like 17 to me.
Today I went for quenching and tempering.
Man, that wrought lets out some vicious slag at high heat.
I first thought I had a bunch of stress cracks along the edge. (as-quenched edge hardness laughed at my 64HRC chisel though)
The tempering and wire wheel clean up showed nice clean steel. Still some slag staining, but that should grind out (hopefully anyway)
Those are going to look sharp!  (no pun intended, Josh!)
Chris
www.chrischristenberry.com
WHEW!!!  If I could only know now what I "thought" I knew back then....................
4 hours ago, Doug Webster said:
Hurry up and finish this already.
https://getyarn.io/yarn-clip/b2b4d157-0298-4f8a-ab3c-c0fd7213fa40
  • Haha 1
Bravo! Nice shape and good welds too. Looking forward to more progress
And so here it is.
After grinding to 220 on the belt, I drew back the tangs.
Then it's on to setting the shoulders. I decided to cut these for all four shoulders. Fitting a triangle tang is a bear to get tight. The 4-shoulder method gives me a little play.
During one operation, the tang sliced the 2x72 belt, got jammed between the work rest and the platen and nearly took the top joint of my pinky off.
Good thing I keep super glue around...…..
It also put a small chip/crack in the edge. I had to grind that out.
Finish sanding to 400 grit and two 5-minute etch cycles in FeCl. Add maker's marks.
That wrought iron spine let out a few voids in the etch.
I think I  will leave them alone. (even the one in my maker's mark)
  • Like 4
Beautiful work,Joshua.I especially like that texture,before final grind(i know it'd not be the most practical finish for a knife:)!
But yeah,great looking puukot!
  • Joshua States changed the title to New project-States/Weller collaboration
