Zane Thompson 6 Posted December 27, 2019 Share Posted December 27, 2019 had some time on Christmas to do a little forging so I decided to try and forge out my first full tang blade. gotta say i'm pretty happy with how it's turned out so far. I used a 1 1/4" x 5" x 3/8" piece of leaf spring and ended up with a blade that has a .225 thick spine at the ricasso, a 5 1/4" cutting edge and is just under 10 1/4" oal. was able to get the distal taper in the blade and the tang, forged in the bevels and made sure it was completely straight. first time I remembered to get all that done in the same blade. here are some pics right after it was forged. and here are some pics after I profiled it and did some light grinding. i love the look of Brute de forge knives so I'm probably not going to go any higher with the grind. and before heat treat i'll need to pop it back into the forge and try and re-texture the ricasso area as it got cleaned up some when I flattened the tang. i'm thinking maybe bone for the scales and copper pins, but haven't decided for sure yet. 1 https://www.lonestarcustomgrips.com/ Link to post Share on other sites
Zeb Camper 787 Posted December 27, 2019 Share Posted December 27, 2019 Looks good so far! 1 Link to post Share on other sites
Rob Toneguzzo 839 Posted December 29, 2019 Share Posted December 29, 2019 Great job 1 "Old dogs care about you even when you make mistakes" - Tom HALL - Old Dogs, Children and Watermelon wine. Link to post Share on other sites
Zane Thompson 6 Posted December 30, 2019 Author Share Posted December 30, 2019 Thanks y'all! was able to re texture the ricasso area this evening. as soon as i have time i'll finish grinding it and then try for the heat treat. https://www.lonestarcustomgrips.com/ Link to post Share on other sites
Joshua States 2,466 Posted December 30, 2019 Share Posted December 30, 2019 2 minutes ago, Zane Thompson said: Thanks y'all! was able to re texture the ricasso area this evening. as soon as i have time i'll finish grinding it and then try for the heat treat. Drill your pin holes before HT. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Zane Thompson 6 Posted December 30, 2019 Author Share Posted December 30, 2019 5 minutes ago, Joshua States said: Drill your pin holes before HT. definitely! https://www.lonestarcustomgrips.com/ Link to post Share on other sites
