Alan Longmire Posted January 3, 2020 Share Posted January 3, 2020 Looks great! Link to comment Share on other sites More sharing options...
Dan P. Posted January 3, 2020 Share Posted January 3, 2020 On 1/1/2020 at 9:42 PM, jake pogrebinsky said: Right on,Chris,glad you enjoyed it!:) Here's another cool video pertaining to overlaying the bit: Here the bit is not pre-shaped,also it appears to be more modest in size... One must remember though that in Sweden of the time re-steeling an axe was a common and accepted procedure(kinda periodic,like re-soling a pair of decent boots). So the eye and poll of an axe was viewed as a permanent part(small wonder,it';s not easy to forge),while the bit was disposable. That is one of the reasons that there isn't really hard and fast rule for the angle of convergence of an axe blade....It was a sliding kinda deal.... I'm mostly imagining the astonishing quality of that iron he's using. You couldn't treat my wrought like that! http://www.prendergastknives.com Link to comment Share on other sites More sharing options...
jake pogrebinsky Posted January 3, 2020 Share Posted January 3, 2020 Hey Dan!:) No,i'd imagine that you're more likely to encounter some cruder,dirtier grades among the structural/architectural iron,even though they may pre-date this scene. At the time this video was shot the industrial world had already found cheaper substitutes for that good Swedish iron...Ironmaking in Sweden was dying(this particular smith unemployed and almost literally starving at that juncture),exports of iron or tools from Sweden down to almost nothing. Sweden had those lovely kinds of ore,+ centuries of experience in processing it,+ their coniferous charcoal...Both ore and charcoal pure as driven snow... But the world no longer had any use for it. A friend who uses an old Wira axe says that in sharpening,and even in handling the tool he can "feel" the loveliness of that iron... 1 God is in his heaven,and Czar is far away... Link to comment Share on other sites More sharing options...
jake pogrebinsky Posted January 3, 2020 Share Posted January 3, 2020 1 hour ago, Aiden CC said: Got this profiled and heat treated this morning. Sweet,Aiden. You're hitting it very close to the holy Grail of axe-forging,minimum shaping by grinding. God is in his heaven,and Czar is far away... Link to comment Share on other sites More sharing options...
jake pogrebinsky Posted January 3, 2020 Share Posted January 3, 2020 1 hour ago, Dan P. said: astonishing quality of that iron he's using P.S. Ironically,this iron was not without it's own connection to England...(was Anything,in Industrial Age?:) https://en.wikipedia.org/wiki/Lancashire_hearth 1 God is in his heaven,and Czar is far away... Link to comment Share on other sites More sharing options...
Dan P. Posted January 4, 2020 Share Posted January 4, 2020 17 hours ago, jake pogrebinsky said: P.S. Ironically,this iron was not without it's own connection to England...(was Anything,in Industrial Age?:) https://en.wikipedia.org/wiki/Lancashire_hearth Years ago I was working on a big c.17th (I think?) restoration project down in London. All of the original iron was of course.... Swedish! 1 http://www.prendergastknives.com Link to comment Share on other sites More sharing options...
Aiden CC Posted January 5, 2020 Author Share Posted January 5, 2020 (edited) Got a bit more done today. The handle is roughly fit and shaped. It needs a little cleanup and fit adjustment tomorrow, then I’ll sharpen it and it will be ready to hang and oil. After using my first one a bit, I decided to make this handle a little slimmer and straighter with a larger radius on the palm swell. Definitely two pretty different hatchets. Edited January 5, 2020 by Aiden CC 2 Link to comment Share on other sites More sharing options...
charles wu Posted January 6, 2020 Share Posted January 6, 2020 so sexy 9 Dragon metalworks - http://9dragonmetalworks.com--- The more traditional, the more modernPast Projects: www.etsy.com/shop/handmademetalworks Link to comment Share on other sites More sharing options...
Joshua States Posted January 7, 2020 Share Posted January 7, 2020 Aiden, you are screaming right along. Hat's off to you on these two. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Aiden CC Posted January 9, 2020 Author Share Posted January 9, 2020 On 1/6/2020 at 7:54 PM, Joshua States said: Aiden, you are screaming right along. Hat's off to you on these two. Thanks! I’ve been working a lot to wrap up a handful of knives, but finally got it done. I’m a lot happier with the cross section of this one, though I wish I had made the eye a little further back and used that material to make the bit a little longer. Definitely a better chopper than the first one, and after I fixed my drift, the hang went a lot better with no gaps in the eye. It fits in the same sheath, so I may just put another notch in the belt for now. 2 Link to comment Share on other sites More sharing options...
