Alan Longmire Posted October 14, 2021 Posted October 14, 2021 No, but it should be top quality, providing the teeth are still sharp. 1
Jeroen Zuiderwijk Posted October 18, 2021 Posted October 18, 2021 You know, I've found a great use for cheap, case hardened files: you can bend them easily, which is quite handy if you have to file inside all kinds of curved shapes. 1 Jeroen Zuiderwijk Facebook page: https://www.facebook.com/barbarianmetalworking
Gerhard Gerber Posted October 18, 2021 Posted October 18, 2021 Completely missed this thread.... I bought 3 new Pherds to level up my draw filing game, then realized my first set of no-name brand files were passed their sell-by date. The tool shop where I get them stocks a huge selection, if I buy them without a handle the Pherds are reasonably priced and I know when they are dull, they can be turned into knives. There's a smaller 1st cut halfround that sticks around for handle fine tuning, the new one bites a bit deep at times....
Randy Griffin Posted April 18, 2022 Posted April 18, 2022 Found these a couple days ago. The rasp on the right is 16”. Some manufacturers I haven’t heard of. Kearney & foot, McCaffrey and Johnson. All are made in USA. I know the Nicholson and Simonds are good steel but what about these three? I got them only for the steel. They are pretty worn out. and what about that narrow file fourth from the right? What is it? It’s a Nicholson USA but I never seen one like it. The front and back and one edge is flat but one edge is rounded. Thanks for looking
Alan Longmire Posted April 21, 2022 Posted April 21, 2022 I don't know those other brands, but the Made in USA means good steel, at least on the big cabinet rasp. The hoof rasp may or may not be, but most likely is. The skinny one is a pillar file. I forget exactly what they're for, but I remember the shape. Maybe keyways?
Randy Griffin Posted April 21, 2022 Posted April 21, 2022 Thanks Alan. I’ll keep that one just because it’s different. After I cleaned them up several still had some life. I’ll keep those as well. I plan to use the rasps for wood and hot work. There’s a website, American made files, that had some information about the three manufacturers. Basically they’re all old companies that were mostly bought out by Nicholson in the early 1900’s.
Daniel W Posted April 22, 2022 Posted April 22, 2022 I also use one of those big 16' rasps, they are monsters in wood work. I have two of them and have designated one for hot rasping and the other for heavy wood removal. I had believed those big rasps were some part of the farriers trade because of how similar the teeth are to a farriers rasp. Those are easily a mate to a draw knife.
jhobson Posted May 26 Posted May 26 (edited) I have a lot of files. A top tip I got from Ford Hallam, who passed it on from ??? .... nicholson magicut file hog off metal but leave a relatively good surface finish. I think they are intended for plastic (?!) but work really well on annealed W1. Get one - not too expensive. What I would like to find is a left handed file. Well, lots of different ones. Ever watched a cack-hander file? Either the process looks weird or the finish is rutted. You can get lh pivot files intended for use on watchmakers lathe but they are small and incredibly fine... and expensive (lh vs rh means you work over or under the workpiece). I have tried a few large files which were intended for lathes, and some appeared to be LH in the pictures, but they turned out to be RH on arrival. The have a different pitch angle for the cutting of the teeth. Cheap needle files ... bad. Get a few good swiss ones rather than a full set of cheaper ones. Favorite shapes: First swiss pattern half round. Second would be a three square with one side ground off 'safe' - can also sharpen saws. Escapement files leave a finish you can buff to a polish - but they are very small and very expensive. However, if you know any second-hand shops these are often chucked in the same bin as all other needle files and can be a bargain. Look for square section tangs. Hablis files fill the gap between needle files and larger patterns. I find my half round coarse hablis very useful. Hand-stitched rasps (for woodwork only!) are worth the money... unless you are prone to losing things Edited May 26 by jhobson
