Now that my damascus class is over it's time to start thinking about my next project.  This time I'm reverse engineering it and creating a knife to fit the handle scales which in this case are some beautiful mastodon ivory scales.
IMG_7844_opt
With the temps what they were this morning, the forge felt pretty good.
IMG_7855_opt
IMG_7857_opt
IMG_7859_opt
IMG_7863_opt
I left the tang in line with the blade for the dogbone type hilt.  It will get a frame tang with an internal pommel nut.
6 minutes ago, Alan Longmire said:
Excellent forging, as usual.  B)
Thanks, Alan.  I had other work to be done but the shop was so cold that I fired up the forge instead.;)
Looking good Gary.
It's funny.  Your shop pics have a whole new meaning for me now that I can visualize where everything is outside the frame of pic.
Clean forging. I wish I could somehow speed click a button and squire those skills. In the mean time I'll struggle away. Lol.
Thanks for sharing.
10 hours ago, Joël Mercier said:
:lol:
Need I say more?
It's all in what you're used to, and Fahrenheit is much more precise...:P
I am fluent in all metric/SI measurements except temperature.  They didn't start me young enough, I guess.
H/T'ed and in the tempering oven. Hopefully I'll have some good activity here. H/T'ed to 1485 & quenched in Park's 50.
Edited by Gary Mulkey
Originally I had intended to give this one a traditional dogbone handle with tapered scales & domed pins.  However, that would have required removing most of the color from these mastodon bark scales.  They have such a nice blue/green color that I decided to leave them natural and not taper the scales.  (the escutcheon inlays will be 416)  I think rather than using an internal pommel nut, I will through pin the tang under the escutcheons.  Since I never do take-down handles it really doesn't matter as both methods work well.
IMG_7881_opt
I've most of the machine work done.  There's plenty of hand work to go however.;)
I've etched this one enough to see that the blade got a secondary hamon in addition to what I had planned.  I'm a little disappointed but you never know with W steels exactly what will happen in the quench.  It's kind of like Damascus patterns, no two will ever be the same.  It will still make an attractive blade though.
IMG_7885_opt
13 hours ago, Alan Longmire said:
Looks like that new stuff is a good bit stronger than FeCl.  Pretty wild pattern!
I believe that it may be slightly stronger.  It does need to be warm though.  FeCl is probably better at low temps.
