t cudworth 39 Posted February 12, 2020 Share Posted February 12, 2020 This is a great thread. I had these questions for a long time. I never knew much about wood sealing, so i have experimented quite a bit in the past. If someone could expand a bit on using ca glue and then polishing, that would be great. Also, what you all do for polishing and buffing the handle, wood, antler, copper, bone etc. These 2 i have almost done are black walnut, copper spacers, and antler. The top one is sanded up to 2500, buffed on a muslin wheel and the 2 coats of Danish oil. Bottom one is same story, but with boiled linseed oil. Not much color difference, but im also wondering about sealing differences. Almost seemed like the BLO shrunk the wood on the smaller one, because I sanded the handle smooth, then after 2 coats and drying, the copper spacers were raised a bit? Tom Link to post Share on other sites
Daniel W 82 Posted February 16, 2020 Share Posted February 16, 2020 (edited) Now that would be a question of did you harvest this walnut or was it already store bought and kiln dried before you worked with it? There is a limited chance that the wood has shrunk around your copper because it is still in a state of stabilizing from one environment to the other. There is only a very minor chance of that if the wood was already kiln dried. I believe the only reason behind shrinkage in wood is the loss of moisture within it. Did anyone bring up clear epoxy for a wood finish? Works pretty similar to crazy glue and has a really good advantage to filling open grain woods. Again it's like a liquid plastic. Edited February 16, 2020 by Daniel W Link to post Share on other sites
David Pessall 34 Posted March 3, 2020 Share Posted March 3, 2020 Would you use a wood sealer for pores before using Tru-Oil? (for claro walnut) Thanks Link to post Share on other sites
Garry Keown 946 Posted March 3, 2020 Share Posted March 3, 2020 3 minutes ago, David Pessall said: Would you use a wood sealer for pores before using Tru-Oil? (for claro walnut) Thanks I wet sand walnut with BLO to fill the pores before applying the finish to the handle 1 Link to post Share on other sites
Jonathanbradshaw 9 Posted March 3, 2020 Share Posted March 3, 2020 Do these finished apply to stabilized woods too? Or are they treated differently? Link to post Share on other sites
Alan Longmire 2,741 Posted March 3, 2020 Share Posted March 3, 2020 1 minute ago, Jonathanbradshaw said: Do these finished apply to stabilized woods too? Or are they treated differently? All you can do to stabilized wood is sand it fine and buff to a shine. It's mostly plastic, after all. Link to post Share on other sites
Jonathanbradshaw 9 Posted March 4, 2020 Share Posted March 4, 2020 Thanks Alan. That’s what I thought. But having only worked with stabilized wood once I wanted to make sure I wasn’t missing something if these finishes would improve the end product. Link to post Share on other sites
