Don Wilwol
longest heat treat
what is the longest knife or other sharp pointy thing you've successfully heat treated in a single burner propane forge?
26 inches in propane.  54" in charcoal.  It's all in the stroking it through the hot spot.  Randal Graham used to do 28" katanas in a vertical forge with a 4" hot spot.  It works fine if you have the patience.  Hardening is the easy part with long blades, it's tempering that gets hairy.
I now have a 60" heat treat forge that is technically a single burner (1" T-rex venturi), I just haven't fired it up yet.
What Alan said is true.
