Hwzt all. Another big project with a few firsts out the way for me. It's a 17" total length bowie, take down construction with a copper frame handle.
The steel started out as 3 separate pieces of 1070 that I forge welded into one big billet. I did clay it and differentially heat treat it but no hamon showed up in polishing, so not sure what happened there.
Here are the details
Steel: 1070 (3 layers forge welded together, hada technique I believe)
Riveted langets: copper
Guard: 5160
Spacers: copper and African blackwood
Frame: fileworked copper
Handle scales: African blackwood (dalbergia melanoxylon)
Pommel: copper
Pommel nut: 1070
Sheath: hand carved and stitched veg tan
Here is the final shots (also tried my hand at some editing), followed by pics of WIP.
Original design work
Successfully forge welded the 3 layers of 3mm 1070 plate together. Was surprised to get an average of 8.5mm thickness across the billet after setting the welds
my forging is still very much on the safe side. Forge thick and over scale, grind to final shape and dimensions. I did get some distal taper in at least.20200207_182522.jpg
just after quench. Nice and straight and I thought the hamon took but it never showed up again.20200210_115408.jpg
Final shots
Edited by Ross Vosloo
8 hours ago, Joshua States said:
Did you acid etch to try and bring the Hamon out?
Ja I did. There is definitely a difference in etch between the edge and the spine where I played, but no hamon line. It just blends from one to another and not very good looking at all, that's why I just stuck with a plain finish. No idea what may have happened.
46 minutes ago, clint c said:
Nice work Ross, lots of details and many pieces involved there! And who doesn’t like a giant blade....
Clint
Thanks Clint!
