Kevin Jeffcoat Posted April 22, 2020 Share Posted April 22, 2020 (edited) Started work on this 20lbs propane tank yesterday. Edited April 24, 2020 by Kevin Jeffcoat Update 1 Link to comment Share on other sites More sharing options...
Wayne Coe Posted April 22, 2020 Share Posted April 22, 2020 Check out the Build a Gas Forge and the Ribbon Burner attachments on the Forge Supplies page at www.WayneCoeArtistBlacksmith.com. Let me know if I can help you. Wayne Coe Artist Blacksmith 729 Peters Ford Road Sunbright, Tennessee 706-273-8017waynecoe@highland.netwww.WayneCoeArtistBlacksmith.com Link to comment Share on other sites More sharing options...
Kevin Jeffcoat Posted April 23, 2020 Author Share Posted April 23, 2020 I have read both your building instructions. I appreciate the information, it’s really good content. I’ll be running a “Frosty-T” style burner that I’ve already built. I’ve been debating cutting an opening in the back of the bottle. After all the forums I’ve gone through i decided to put one in just in case. Link to comment Share on other sites More sharing options...
Kevin Jeffcoat Posted April 24, 2020 Author Share Posted April 24, 2020 Day 3 progress. Cut the face off. Found my jig saw did a much cleaner job than the angle grinder. Forge is stuffed with 2” ceramic insulation. Welded the face back on. Welded the base on. Link to comment Share on other sites More sharing options...
Brian Dougherty Posted April 24, 2020 Share Posted April 24, 2020 Looking good. -Brian Link to comment Share on other sites More sharing options...
Jeremy Blohm Posted April 24, 2020 Share Posted April 24, 2020 (edited) On 4/22/2020 at 8:06 PM, Kevin Jeffcoat said: I’ll be running a “Frosty-T” style burner I have a frosty T burner that a friend of mine built and I am able to run it all the way down to under 1500°f. This is important when thermalcycling and quenching. Oh yeah....nice vice!!! Edited April 24, 2020 by Jeremy Blohm 1 Link to comment Share on other sites More sharing options...
Kevin Jeffcoat Posted April 25, 2020 Author Share Posted April 25, 2020 Day 4. Fired up the burner for the first time after adding the air chokes. Not sure if I’ll have much use for them but I wanted to add them in the event that I needed the ability to fine tune the air flow. FullSizeRender.mov Link to comment Share on other sites More sharing options...
Kevin Jeffcoat Posted April 26, 2020 Author Share Posted April 26, 2020 I installed the table top legs today. The finished product will have bolt on leg extensions. Link to comment Share on other sites More sharing options...
Brian Dougherty Posted April 27, 2020 Share Posted April 27, 2020 The chokes will be handy. At some point you will probably want to be able to adjust your flame to be neutral or slightly reducing, and you'll be glad you have them -Brian Link to comment Share on other sites More sharing options...
Kevin Jeffcoat Posted April 30, 2020 Author Share Posted April 30, 2020 (edited) I got the burner mount fitted, tapped and welded on, the bolt on legs cut to size and drilled(not shown), and 2 layers of high temp paint sprayed on. All that I have left is to cover the ceramic insulation. In a few days I’ll be able to fire it up. I’ll also be adding plate steel on the front and back racks Edited April 30, 2020 by Kevin Jeffcoat Added Link to comment Share on other sites More sharing options...
Kevin Jeffcoat Posted May 4, 2020 Author Share Posted May 4, 2020 And it’s partially completed. Still missing the front and rear plates. I’ll add them eventually. Defiantly glade I added those air chokes. The back one is completely shut and the front one is just cracked open. IMG_3043.MOV Link to comment Share on other sites More sharing options...
Kevin Jeffcoat Posted May 5, 2020 Author Share Posted May 5, 2020 The forge was running for about 2 minutes prior to this. The wrench is about 1/8” thick. I threw it in there just to see how long it would take to heat up. IMG_3060.MP4 1 Link to comment Share on other sites More sharing options...
