Texas Samurai BrisketSword
Dan O'Connor
I am not sure how it was I got away from this forum. Lots of travel with work, time on social media and spending the last couple of years developing anti-scale and hamon clay. Anyway, more back into making blades. The name for this is a bit tongue in cheek I admit. Kind of a hit with the local crowd.
Composite picture of one knife/sword.
Loosely based off of a type of Yanagi-ba.
18" blade
W2 steel
Single bevel
Hollow back
Saya-European yew and desert ironwood
Hamon
Oiled leather sheath for saya
Edited by Dan O'Connor
  • Like 7
Very nice one Daniel! I'm sure you just need to let the weight of the blade do the work on a single buttery stroke.
On a side note, are you, like me, sad that the beautiful hamon is going to get a patina? As much as I like playing with hamons, it saddens me to do one on a kitchen knife because of this :unsure:.
Thanks Dan. Not really that heavy. .190" at the tang and tapers a good bit and the hollow back takes out a goodly amount of weight. The 18" length was more to see if I could do it. 14" is a more manageable length.
Dan!  Welcome back! :D
Excellent re-introduction.  I missed you, man.  We need your knowledge of things Japanese and Texan around here!  Not to mention some good brisket...;)
Beautiful blade and the handle wood is extraordinarily beautiful!!!
I'm glad you back Daniel. Your Japanese  style power hammer was the inspiration I needed to build my hammer.
Thanks Guys.
I get so caught up in the tools, like the hammer I built, as well as the  whys and what fors of bladesmithing/knifemaking, I forget to actually make stuff. Trying to change that. Spent a boatload of time experimenting with hamons.You should see some of the info on the forum. Some surprising revelations. Be prepared to back up your arguments to what I post.  :)Disclaimer- a lot of it will reference the clays I developed, make and sell, but will most likely apply to whatever you are using now.
That’s tremendously marvellous work Dan!
Very impressive.  Thin, long, curved back, differential quench and not warped (not that I would expect it for you, but if I tried to quench a 18" blade that was around 1/8" thick at the spine I'd certainly get warping.  I'm relatively new to this forum, so don't think I've seen your work before.  Really appreciate you sharing the details.
 Ha! Warps like a snake-Multiple times!  Warps when I normalize. Warps when I heat treat. Warps when I grind the hollow post heat treat. That is the beauty of the differential hardening and leaving a bit of meat all over to have room to tidy up. Just take it to my smooth, flat sawmakers anvil and carefully bang it straight each time with a 2lb polished and slightly crowned  hammer.
the blade profile is really cool, im working on a few more swordy things with a similar shape.
the curve in the blade makes it look powerful, it looks larger than 18".
i just noticed it has a chisel grind, i know what you mean about all that straightening, differential hardening is the way to go.
A
12 minutes ago, Joël Mercier said:
One of the busiest I've seen :). What was your clay thickness at spine?
Around 1.5mm
1 minute ago, Alan Longmire said:
So the white is your anti-scale clay and the gray is your hamon clay?
That is correct Alan. More red than gray but yes.
1 hour ago, Alan Longmire said:
I just pinned your post about it in Tools and Toolmaking, and watched the videos again.  B)
Thanks Alan.
Will update it with better contact info.
