Dan Hertzson 29 Posted June 5, 2020 Share Posted June 5, 2020 So I've finally given up on the whole hot stamping thing. Love the idea, but can't get the level of detail consistently with the design I've come up with and the 3/4" diameter Hoenick stamp I purchased. Might work better if I rigged it up in the fly press, but even using the treadle hammer I struggle with getting a deep enough impression. This is what my mark looks like (blue fill is indented, white is proud): So I'm looking at electro-etching. I have an old model railroad transformer that I feel pretty comfortable using for the etch side, but am not sure on two things: Where to get laser cut stencils (I can lose the inner white triangles) Whether you can etch already assembled knives/axes... I'd appreciate any direction. Thanks Link to post Share on other sites
C.Anderson 13 Posted June 5, 2020 Share Posted June 5, 2020 I have a tutorial around here somewhere. You can use laser stencils, or simple vinyl stencils if your design isn't too complicated. Without the triangles that would probably be fine in as small as 1/4" diameter. Link to post Share on other sites
Gary LT 101 Posted June 5, 2020 Share Posted June 5, 2020 @Dan Hertzson, Initially I used this salt water tutorial with a car charger and Kinkos for the vinyl. This was an excellent start for me to get away from hot stamping my trademark. The young man at Fed Ex did my artwork and I bought a 1/2 yard cheap! which lasted a long time., but you have to “weed-out” lettering and it’s slow. However, they don’t cut vinyl anymore, at least in my area, let alone reproduce your artwork. My friend Lauri recommended PICO Elektra and I have been really pleased. They are out of Germany, excellent to deal with and the stencils are durable. I also use their electrolyte for tool steel. With these also use a plain old Lionel Train Transformer, no problems. My best, Gary LT Link to post Share on other sites
john marcus 2 Posted June 7, 2020 Share Posted June 7, 2020 https://www.markingmethods.com/store/pc/viewCategories.asp?idCategory=11 they make nice electro chemical etching stencils yes you can mark finished knives with their set up. Link to post Share on other sites
Chris Christenberry 333 Posted June 7, 2020 Share Posted June 7, 2020 Can't get your link to go anywhere, John. Link to post Share on other sites
billyO 215 Posted June 7, 2020 Share Posted June 7, 2020 1 hour ago, Chris Christenberry said: Can't get your link to go anywhere, John. Hmmm...worked for me, Chris. Link to post Share on other sites
Chris Christenberry 333 Posted June 7, 2020 Share Posted June 7, 2020 1 hour ago, billyO said: Hmmm...worked for me, Chris. Well dang my hide, musta been holdin' my tongue on the wrong side of my mouth! Works for me now too! Oh well! Link to post Share on other sites
Brian Myers 121 Posted June 8, 2020 Share Posted June 8, 2020 You can certainly etch after assembly. As for making your stencils, if you're good enough with an image program look around and try to pick up a Cricut (pronounced cricket) vinyl cutter. Yes they are a bit on the expensive side, but you can usually find them second hand for a decent price. The vinyl that it uses is sticky-backed so it adheres well and it can resist most etching solutions no problem. Link to post Share on other sites
Dan Hertzson 29 Posted June 8, 2020 Author Share Posted June 8, 2020 Thanks all for the help and advice. Really appreciate those who took the time to answer. Link to post Share on other sites
billyO 215 Posted June 8, 2020 Share Posted June 8, 2020 14 hours ago, Chris Christenberry said: musta been holdin' my tongue on the wrong side of my mouth Is that why things don't work for me sometimes? Thanks for the tip. Now if I can just remember to pay attention to what side the next time I have a failed weld.... Link to post Share on other sites
