JenniferP Posted June 13, 2020 Share Posted June 13, 2020 So I posted a thread on the Accu-test HRc tester which is super simple with a ball drop.. This unit ramps up some with more accurate results possible and is really a neat unit for what it does. It basically takes a larger lab type HRc tester and moves it into a hand held unit. Its basically designed like a Micrometer but with an extra arm that rests on the dial indicator.. When the correct pressure is applied it opens the C some amount and when the pressure is removed it tells the difference between the depth of penetrator for that given pressure.. Much like a Lab machine in principal, but in a very small package. This unit has several anvils, an extension and several alum test blocks, a brass one and 2 steel 60HRc and 33HRc. AmesManual (1).pdf 1 Facebook: https://www.facebook.com/jlpsinc Facebook photos: https://www.facebook.com/pg/jlpsinc/photos Youtube channel: https://www.youtube.com/channel/UC8WRbArfgi8kSaDek7kh_1Q?view_as=subscriber Google Photo's: https://goo.gl/photos/jNR8MRdz5TSU3Nm47 Link to comment Share on other sites More sharing options...
john marcus Posted June 13, 2020 Share Posted June 13, 2020 i have an old one you can have infinite edge cutlery Link to comment Share on other sites More sharing options...
JenniferP Posted June 13, 2020 Author Share Posted June 13, 2020 4 hours ago, john marcus said: i have an old one you can have Thanks John, Pm sent.. that is extremely generous and will be excellent to have.. Facebook: https://www.facebook.com/jlpsinc Facebook photos: https://www.facebook.com/pg/jlpsinc/photos Youtube channel: https://www.youtube.com/channel/UC8WRbArfgi8kSaDek7kh_1Q?view_as=subscriber Google Photo's: https://goo.gl/photos/jNR8MRdz5TSU3Nm47 Link to comment Share on other sites More sharing options...
HSJackson Posted June 13, 2020 Share Posted June 13, 2020 I have an old one and I looked into getting it refurbished, but they won't touch units over a certain age. There's a serial number cutoff they don't go beyond listed on their website. Mine is definitely too old. Link to comment Share on other sites More sharing options...
JenniferP Posted June 13, 2020 Author Share Posted June 13, 2020 2 hours ago, HSJackson said: I have an old one and I looked into getting it refurbished, but they won't touch units over a certain age. There's a serial number cutoff they don't go beyond listed on their website. Mine is definitely too old. Ah, that is a bummer.. It seems many places now won't do older items.. Post up a photo or the like if you don't mind.. What is it doing or not doing? Not accurate or different problem? Facebook: https://www.facebook.com/jlpsinc Facebook photos: https://www.facebook.com/pg/jlpsinc/photos Youtube channel: https://www.youtube.com/channel/UC8WRbArfgi8kSaDek7kh_1Q?view_as=subscriber Google Photo's: https://goo.gl/photos/jNR8MRdz5TSU3Nm47 Link to comment Share on other sites More sharing options...
