Dan K Posted August 8, 2020 Share Posted August 8, 2020 (edited) Hi All. I was wondering, what is he "cleanest" way of making knives. I have a small woodworking shop, that I dont want to cover in soot and grinding dust. But I want to make a few knives a year for testing and gifts. My thinking was: Buy bar stock and cut it out myself. Or have it waterjeted by a third party. Grind in a separate room. Then heat treat in ovn (even heat or something other) Im not sure, but I believe a small propane forge would create to much moisture and soot? The woodshop is 12,5ft x 18,5ft or 230 sq ft, with a smal "storage" area of 70sq ft where I can grind. If you have other ideas, please share! Edited August 8, 2020 by Dan K Link to comment Share on other sites More sharing options...
Dan K Posted August 8, 2020 Author Share Posted August 8, 2020 This might sound stupid, but could I use a Evenheat ovn, to heat the steel, then shape it on a anvil? A electric forge... :p Link to comment Share on other sites More sharing options...
Alan Longmire Posted August 8, 2020 Share Posted August 8, 2020 Using an Evenheat as a forge would be highly inefficient. You only get 20 to 30 seconds of forging time per heat no matter the heat source. Propane forges don't produce any soot, and the moisture is negligible once they come to temperature. Grinding can be done in a small space, you just need good ventilation and a respirator. There is also the option of hand filing. If you go pure stock removal and you have the Evenheat, you don't need a forge. If you want to forge, you can always do it outdoors. Welcome aboard! Link to comment Share on other sites More sharing options...
Dan Hertzson Posted August 8, 2020 Share Posted August 8, 2020 Cleanest forging is most likely from an induction forge, but that is quite the investment for just a couple of blades a year. Agree that keeping metal dust down is best done in separate room as Alan advocates. Link to comment Share on other sites More sharing options...
Dan K Posted August 11, 2020 Author Share Posted August 11, 2020 (edited) Well.. purchased a new Peddinghaus 77lbs anvil and a Heuer 180 vice (for other shop duties as well). Lets see if I find a use for it Edited August 11, 2020 by Dan K Link to comment Share on other sites More sharing options...
Joshua States Posted August 13, 2020 Share Posted August 13, 2020 The absolute "cleanest" way I can think of is to buy the blade kits and put them together followed closely by buying blade blanks and putting handles on them. Alan's idea of stock removal with files is pretty clean, but if you want to grind, it will get dusty. Maybe think about a dust collection system. If you are really opposed to creating a mess you have to clean up, find a different hobby Forging in a small propane single burner is easy, fun and if you focus on small blades or thin ones, you won't have much steel and time to create a huge mess. Welcome to the madness. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
billyO Posted August 13, 2020 Share Posted August 13, 2020 Hello Dan, and as Joshua said, welcome. Not sure where you live or how close your neighbors are, but there are a lot of folks that build their forge stands on casters so they can roll the stuff out of the garage while in use. Your peddinghaus is portable, and a relatively inexpensive tarp/tent cay keep the rain off while working. RIP Bear....be free! as always peace and love billyO Link to comment Share on other sites More sharing options...
