Now what do I do with it?
That is too cool. How did you do the texture? I'm guessing it's about 6 inches long.
I think that this is a perfect opportunity to make cabinet door hardware.
Tig or Mig welded texture?    Could be a cool handle for a shield or something.   Do you have the capabilities to hollow it out ?  Then it would be a cool handle on a long blade or walking staff or cane.    Weld spikes to both ends and use it as a thrower ?    Make it into a roller to texture leather or wood (if heated)?   Cool looking candle holder ?    Neat handle for a wooden chest or fancy cabinet.   Or a Pull handle for a door.   I'm still leaning towards adding a spike or two on the ends.    Or you can cut it in two and add a chain to make a manrikigusari.
Cool texture.  Looks like a brain.
Edited by Bruno
I wanted to put it up before I said the how.  Which is a long time in a tumbler.  I put a bunch of castoffs in the tumbler to add some mass and after a long time, this is what happened.
7 hours ago, Brian Myers said:
I could see chunks of that used as pommels!! 1/2 is pretty small for that though.
I'm going to put in a few handle size to see if it happens again.
Were there any non-ferrous metals in the cast-offs you threw in?  If so, the iron, and other metals mixed with the liquid may have made enough of a battery to cause electro-chemical etching to occur.
It is a fantastic effect.  I hope you can repeat it!
I would think it had to be significantly rusted before tumbling and the patterning/pitting is from the rusting, not the tumbling.  But I could be wrong.
Yeah, that's an interesting effect.  I wonder if it's work-hardening during the early stage of tumbling, which then prevented erosion of the corners?
Sort of like peening?
On 10/16/2020 at 11:29 AM, Gerald Boggs said:
No idea, but I'm going to try to repeat this.  This took a few months, so it will be a while.
A few months in the tumbler?
