Chris Christenberry 333 Posted November 14, 2020 Share Posted November 14, 2020 Working on my first folded sheath. Getting ready to sew it. I need to "moisture fit" the knife to the sheath. Is that step done before putting a finish on the sheath, or after? Link to post Share on other sites
Alan Longmire 2,639 Posted November 14, 2020 Share Posted November 14, 2020 Up to you whether to do it before or after dying the leather, but definitely before the final finish. For pretty much all leather work with veg-tan it needs to be slightly moist during all steps. I usually cut out the pattern, dampen, then do the rest, adding water if and where needed. If you can't finish the job in one session, put it in a ziplock bag to stay moist. If you're in a hurry you can wet-mold with acetone, but that tends to stiffen the leather and of course you can't glue it until the acetone is totally evaporated. 1 Link to post Share on other sites
Alex Middleton 480 Posted November 14, 2020 Share Posted November 14, 2020 As an option, check out Garry Keowns hot waxing technique. He's posted a couple of videos on here somewhere. It gives you an opportunity to fit the sheath at the same time you waterproof it. I've done it a half dozen times or so and dont see any reason to try anything different. 1 Link to post Share on other sites
Chris Christenberry 333 Posted November 14, 2020 Author Share Posted November 14, 2020 (edited) Thanks, Alan, just what I needed to know. Appreciate the heads-up, Alex. I keep that video in a file on my desktop. So I'm very familiar with his Paraffin soaking treatment. Plan on using it for some of my sheaths, but this one is just a sheath to protect the blade for a knife that will only leave the display case to be shown to someone. Don't think a waxy sheath quite fits that need. I think it's a perfect treatment for a sheath that will be used out in the weather..............but this one won't be. Edited November 14, 2020 by Chris Christenberry Link to post Share on other sites
Chris Christenberry 333 Posted November 15, 2020 Author Share Posted November 15, 2020 Okay, got the sheath stitched and the knife is form fitting right now. (is that a verb??) Anyway, my next question is how long to do leave the knife in the sheath as it dries? Link to post Share on other sites
Alan Longmire 2,639 Posted November 15, 2020 Share Posted November 15, 2020 Until the sheath is no longer pliable. That may be overnight, so I hope you wrapped the knife in plastic! 1 Link to post Share on other sites
Chris Christenberry 333 Posted November 15, 2020 Author Share Posted November 15, 2020 Indeed I did, Alan. Thanks. Kind of thought it best to leave the knife in the sheath until it was dry, but one video I found said to dry it without the knife in it. Didn't make sense to me. Oh, when fitting the knife, I kind of washed out some of the stamp impressions. Kind of hard to re-stamp them now, but in the future, is there a trick to keep from doing that? Onward and upward. Link to post Share on other sites
Joshua States 1,664 Posted November 16, 2020 Share Posted November 16, 2020 5 hours ago, Chris Christenberry said: I kind of washed out some of the stamp impressions. Kind of hard to re-stamp them now, but in the future, is there a trick to keep from doing that? Stamping is best done when the surface is dry, and the core is still moist. Don't be afraid to stamp deeply. You want a deep impression to hold the form when any moisture is added (dye, wax, oil, etc.). However, the stamps that go around the bend are going to fade a little no matter what. 1 Link to post Share on other sites
Chris Christenberry 333 Posted November 16, 2020 Author Share Posted November 16, 2020 My stamping was deep. Just lost a good part of it that went over the handle of the knife. I'll be more careful next time. Link to post Share on other sites
billyO 211 Posted November 16, 2020 Share Posted November 16, 2020 8 hours ago, Chris Christenberry said: is there a trick to keep from doing that? What I've done is pre-form the bend and do the stamping around the bend using a dowel or something inside as a bick. 1 Link to post Share on other sites
Brian Myers 121 Posted November 16, 2020 Share Posted November 16, 2020 17 hours ago, Chris Christenberry said: My stamping was deep. Just lost a good part of it that went over the handle of the knife. I'll be more careful next time. It may seem deep, but might not be. Its a common mistake to not allow the water enough time to soak in. Make sure you dampen the material well, the let it sit for about 5 to ten minutes. The surface will seem almost dry, but the core will be good and damp. Then do your stamping. 1 Link to post Share on other sites
Chris Christenberry 333 Posted November 16, 2020 Author Share Posted November 16, 2020 Now that's an interesting trick, BillyO. I'll keep it in mind. Which is what I think I did...........but I've been known to screw things up before. Link to post Share on other sites
