Axe Forging with Jim Austin
I took a couple of days off work to spend time with Jim Austin in Oakland and take his axe forging class. The objective was to transform the bar of steel into that axe head:
This is basically all forging work without really much grinding and or filing afterwards. We made two axes and here is the one I made (under Jim's excellent tutelage):
If you are interested, I can also post some photos from all the forging stages.
  • Like 4
Yes,please,as many as you can.
It's Really cool that you made the time and the effort to do this,Niels,good for you and thanks in advance.
What an enviable undertaking. I attended Jim's axe demo in SLC at the 2016 ABANA conference. He's a fantastic teacher. Your ax head is a brilliant piece of forge work.
I did not take any video as that would have easily doubled the amount of time but here are some photos.
Using a center punch to show the lines where material for the eye is going to be separated:
Fullering on the line - the goal was to split the punched dots in half:
With the material separated, the rest of the eye is fullered to increase the width to about 3 1/2 in:
I'll post more pictures when I have some time. That said, watching Jim demonstrate all this makes you appreciate the skill and experience to do this efficiently.
  • Like 3
In preparation for welding the eye, the transition to the blade is upset to give it some more material:
Then the surfaces are cleaned and prepared for welding with some borax:
Afterwards, the piece is bent so that the blade parts meet perfectly and are ready for forge welding:
Interesting. 6.5 cu. inches of material. The Danish Broad axe video starts with 4" x 2" x 3/4", or 6 cu. inches. Very similar starting stock with dramatic differences in form.
Here are a few more pictures. The axe head right after forge welding:
Here Jim is forming the eye on the mandrel:
And the axe heads after the eye shape has been refined:
  • Like 3
Thanks,Niels.It's inspiring seeing Jim's tools and methods,very clean and controlled forging.
If i may ask,why was this particular form/style/et c. of a axe chosen?
Did you discuss any specifics of the kind of tool that you're going for,or was it more in a format of a general exercise?
In any case,great to see these photos,thanks.
From my perspective, it was a general exercise. Jim ended up visiting a bunch of smithies in Norway and Sweden a few years ago. I believe this is one of the simple axes he observed there. I mostly wanted to get a sense for the process and an excuse to actually spend two days blacksmithing. My usually shop time is unfortunately only a couple of hours each week at the moment :-(
