Designing a Type XVIIIb
Ok, disclaimer: I know little to nothing about European longswords.  I really really love how they LOOK though, and have always wanted to try to make and wield one! When my wife asked for a sword I showed her the Oakeshott type XVIIIb and she was elated, so we settled on that.
my question is: Does this drawing’s proportions look anything like they should..?  I watched Peter Johnsson’s video’s on youtube a bunch and tried to apply the geometrical design process to this, and I’ve been staring at pictures of Type XVIIIb’s, but I think I’m going blind to my own mistakes at this point...
A huge question mark for me is in the tapering of the blade. I tried to do a convex taper, but I’m wondering if I made the last third of the blade too thin? Base of the blade is set at 1.5” right now tapering to 1/2” over the 31” blade.  I plan to forge it out of 1.5”x1/4” barstock, making the distal taper from 1/4” to ~3/16-5/32~.
Thank You for any advice, revisions, corrections, and otherwise about-faces you see to throw my way!!:D
C06E7804-DFF2-4C3A-A5A4-35E57ABF3CA8.jpeg AAB9A1BF-DF09-48EE-B436-4A07BA9F18CB.jpeg
So I went ahead and started; I was able to get a rough forging done last week, but not quite enough time to get the tang forged out and everything all straightened.  Forged slightly oversize so I had plenty of room to correct errors via the grinder:P
type XVIIIb drawing.jpeg   type XVIIIb forging.jpegtype XVIIIb rough forging.jpeg
All I can add is that with the way the last third of the blade tapers in, that's gonna be one fast sword in the hand!  That's a feature that is seen on some examples.
As for the geometry, I think the guard needs to be a bit longer, so it meets the outside of the circle it's in.  It looks a little short to me otherwise.  The pommel will work IF it's fairly bulbous in three dimensions, like a scent stopper or a mushroom.  If it's flat it'll be too small to do its job.  You can have some fun figuring this out after you have the blade ground and the guard fitted. Just add a bit of weight at the pommel location by taping bits of lead or brass, etc. (something dense, anyway) to the tang until you feel the blade come alive in your hand.
If you watch Peter's video on sword harmonics from Arctic Fire, you'll see he does it with plasticine and it works fine.  It just takes a bigger gob.  The weight is what's important.  Pommels are not about balance as much as they are about tuning the harmonics, i.e. moving the nodes of vibration up and down the blade.  You want the first node in the palm of your dominant hand in the grip.  Ideally the last one will be at the very tip of the blade, and the other one(s) will fall in between.  If the first node is not in the grip, the sword will sting your hand with every blow.
2 hours ago, Brian Dougherty said:
I can't help with the design aspects, but I'll be following along to learn with you as you go :)
Brian - its Always nice to have company when learning new stuff:D
Alan - Thank you for weighing in, I really appreciate it!!
I'll be carving out time soon to watch those Arctic Fire Videos, I've had them saved on the tubes for a while now, just haven't been intentional on watching them:wacko:
I'll be sure to readjust the guard, thank you for catching that!  And I'll be perfectly honest: these pommels and their shapes and designs scare the bejeezers out of me:blink:  My goal was a scent stopper type pommel, but to be honest I'll be happy if I got a pommel shaped object made, lol:lol:
Taking this one slow and steady.  Spent an hour lengthening and straightening the tang.  Its getting so dark lately with sunset at 4:30 and being in the mountains, 5pm is nearly pitch black already!  Really cutting into my forging time here nature...:rolleyes:
It is just proud of the drawing in most dimensions at this point, so next I'm going to grind the bevels cause I'm too chicken to forge them! :unsure::lol:
  • 4 weeks later...
Promise I'm still working on this
Recently was able to profile the blade.  It got a slight bit smaller than the drawing I did due to some forging errors on my end, but I don't think its going to be catastrophic to the balance or aesthetic.
        Blade Profiled and ready to start grinding in the bevels        Couch Corgo for size reference
The Next piece of the puzzle before grinding the bevels was layout, something I am notoriously bad at doing ,lol :rolleyes:
Normally I end up just winging this stuff after a frustrating 10-15 minutes of thinking about what I need to do, but I decided at the very least I would scribe out the center marks and try to adhere to those if at all possible.
I drilled and tapped a bit of brass I had laying around and used my grinder and hand-drill to lathe down one of the set screws, then gave that a heat and dunk in the grinder-bucket water for a quick and dirty heat treat.  It did the job for the moment, although I don't think I did more than case harden the very tip, lol
With some rough lines to start with we are on our way to bevel grinding!  I set a rough edge thickness, but by that time it was time for dinner and there was a rumbly in my tumbly, lol :P
She's starting to slowly come to life, and I can definitely feel the balance and flow develop, even at this early stage!  Can't wait to continue on!!!
