Sean Baumer 0 Posted January 11 Share Posted January 11 I recently won this muffle furnace at an auction i am thinking about adding a PID to it Has anyone done that? Any advice I have not tested it yet because as you can see it has no controls Link to post Share on other sites
dragoncutlery 48 Posted January 12 Share Posted January 12 wheres the eliment? Link to post Share on other sites
Alan Longmire 2,714 Posted January 12 Share Posted January 12 I found this... http://www.hamiltoninstrument.com/index.php?route=product/product&product_id=256 Brandon, these have hidden elements. They're used to do destructive tests on stuff that would coat exposed elements. Link to post Share on other sites
Brian Dougherty 1,167 Posted January 12 Share Posted January 12 Should be a pretty easy "Drop in" replacement for an appropriate PID controller. Link to post Share on other sites
Alan Longmire 2,714 Posted January 12 Share Posted January 12 I found a couple of sites that say they have the manual for PDF download, but you have to register to get it. Seems they're a burnout kiln for dental labs. If all that one is missing is the knob and the gauge, someone handy with electronics (not me!!) should be able to rig something up. Link to post Share on other sites
dragoncutlery 48 Posted January 12 Share Posted January 12 As long as the eliments are in usable shape setting up a pid on that is pretty easy i have one set up to a toaster oven for drying wood hardest part was deciding were to put the thermocouple wich it looks like you will need a new one of as long as your in there i recomend auber instruments for a pid tried the cheeper ebay/amazon option and still cant get it to read temp correctly no issue with the 3-4 i have from auber Link to post Share on other sites
Sean Baumer 0 Posted January 12 Author Share Posted January 12 Thanks everyone, I plugged it in for about 20 minutes last night. It started heating up so it looks like I need a a PID, therocouple and SSR The pdf I read says it will go up to 2000F When you install the PID you bypass the temp control on the front correct? Link to post Share on other sites
dragoncutlery 48 Posted January 13 Share Posted January 13 Yes the pid will be your control you just need a on off switch and if you get one with a timer or other function a switch to activate/reset the function like i have a timer pid from auber on mine that i can set to run for temp and time so when im tempering i have it run at 375 for 160 minutes then it shuts off the eliments and lets it cool and when i get up in thr morning i flip the reset and when its done i have two tempering cycles done and didnt have to watch it i can then check the temper and adjust as needed for the final if i had a ramp pid i could program it to do two or more cycles as long as i new how long the kiln takes to cool to room temp Link to post Share on other sites
