Jaro Petrina 34 Posted January 11 Share Posted January 11 Hello, little question. Assuming I have this burner 300 mmX90 mm and input is 2" (I have 380V blower with 2" pipes) this is 28 holes. 28 10 mm holes has more area than 2" pipe on input of the burner by about 3 holes. 9 mm holes is about 2 holes short. Should I strive for perfect equilibrium in this? 1 Link to post Share on other sites
Jaro Petrina 34 Posted January 12 Author Share Posted January 12 Like this. I remeasured my profile I can use for the burner, its 80 mm. 33 holes around 8,7 mm will give me equilibrium to 2" (50 mm) tube. Why I am doing this My current forge is just too angry with venturi burners. Link to post Share on other sites
Jim Kehler 10 Posted January 12 Share Posted January 12 I'm not sure but I don't think it will matter. The air and gas mixture is under pressure and a difference in area will give you a difference in pressure, you will be adjusting the mixture anyway. 1 Link to post Share on other sites
Sean Blum 6 Posted January 12 Share Posted January 12 Like Mr. Kehler said it wont make a huge difference at that level of imbalance if you had a 2" inlet but 4 10mm outlets it would be an issue. You want as close to same area as possible but its not machinists levels of precision. A good example I can give where this matters if you have to much output vs input you wont pressurize the furthest ports enough to keep the heated atmo from reentering the manifold. The opposite direction is a bit harder to give an example but is problematic in a couple ways. Going slightly over/under wont be enough of a problem to cause burner failure from your current posted design. When you say your current forge is angry with the ventures could you elaborate? Do you mean the amount of dragons breath coming out is way to much or is it something else i'm not seeing in the video? 1 Link to post Share on other sites
Jaro Petrina 34 Posted January 12 Author Share Posted January 12 24 minutes ago, Sean Blum said: Like Mr. Kehler said it wont make a huge difference at that level of imbalance if you had a 2" inlet but 4 10mm outlets it would be an issue. You want as close to same area as possible but its not machinists levels of precision. A good example I can give where this matters if you have to much output vs input you wont pressurize the furthest ports enough to keep the heated atmo from reentering the manifold. The opposite direction is a bit harder to give an example but is problematic in a couple ways. Going slightly over/under wont be enough of a problem to cause burner failure from your current posted design. When you say your current forge is angry with the ventures could you elaborate? Do you mean the amount of dragons breath coming out is way to much or is it something else i'm not seeing in the video? Thanks for that insight Sean. So I need to put a valve to the air duct to be able to tune and needle valve for the gas to get the correct mixture. What you ask - Yeah its lots of dragon breath. You cannot see it here because I m blocking the port, but I think I m burning too much fuel for nothing. It will weld, but just about. Also I have used hard brick inside. Its indestructible, but I think it would be better to have the wool insulation, just with refractory. So when at it, I can easy build this type of burner in my shop and I have finaly found refractory that holds up to 1700 C for the burner and the inside, if I build a new one and this one sell to some who just wants to start quickly. Link to post Share on other sites
timgunn 31 Posted January 12 Share Posted January 12 What size are the gas jets in your "Venturi" burners? Can you change them fairly readily? If you are using mig tips as gas jets, try a smaller size. It may seem counter-intuitive at first, but there is a very high probability it will increase your temperature and dramatically reduce the Dragons Breath. I would aim for about half the area at first; 0.707 times the diameter and see where you need to go from there. Ideally, you want to get to, or just above, the maximum (welding) temperature you'll ever want with the choke slides fully open. Then you can reduce airflow with the chokes to get cooler, more reducing, temperatures for forging. Note that mig tips are sized by the wire diameter they are intended for welding with and the hole is typically about .006" or .015mm bigger than the nominal size. I'd certainly spend a couple of hours playing with the burners you have before embarking on a ribbon burner build. Even if you don't get them working to your satisfaction, you'll become familiar with the effect that varying the mixture has on the flame temperature. Link to post Share on other sites
Sean Blum 6 Posted January 13 Share Posted January 13 40 minutes ago, timgunn said: What size are the gas jets in your "Venturi" burners? Can you change them fairly readily? If you are using mig tips as gas jets, try a smaller size. It may seem counter-intuitive at first, but there is a very high probability it will increase your temperature and dramatically reduce the Dragons Breath. I would aim for about half the area at first; 0.707 times the diameter and see where you need to go from there. Ideally, you want to get to, or just above, the maximum (welding) temperature you'll ever want with the choke slides fully open. Then you can reduce airflow with the chokes to get cooler, more reducing, temperatures for forging. Note that mig tips are sized by the wire diameter they are intended for welding with and the hole is typically about .006" or .015mm bigger than the nominal size. I'd certainly spend a couple of hours playing with the burners you have before embarking on a ribbon burner build. Even if you don't get them working to your satisfaction, you'll become familiar with the effect that varying the mixture has on the flame temperature. I will definitely point you in the same direction as you may have perfectly operational forge that needs some tweaking to get working correctly. 1 hour ago, Jaro Petrina said: Thanks for that insight Sean. So I need to put a valve to the air duct to be able to tune and needle valve for the gas to get the correct mixture. What you ask - Yeah its lots of dragon breath. You cannot see it here because I m blocking the port, but I think I m burning too much fuel for nothing. It will weld, but just about. Also I have used hard brick inside. Its indestructible, but I think it would be better to have the wool insulation, just with refractory. So when at it, I can easy build this type of burner in my shop and I have finaly found refractory that holds up to 1700 C for the burner and the inside, if I build a new one and this one sell to some who just wants to start quickly. So from the sounds of it and the little I see from the video is your current setup has maybe two big problems though its hard to tell from a video that doesn't give perspective like in person. The first one is definitely the construction of the interior hard FB is tough but sucks at all the important parts of being a forge lining after that. Its a huge heat sink and has comparatively no insulation. This might explain why it seems to have a huge dragons breath but still running "cold". I would recommend a layer of 2" blanket and then hard facing the blanket with refractory to save your heath and prevent damage to the blanket. The second problem is if those venturis are similar to the ones I think they are then you might have to much burner for the size of forge its in. The burners are outputting more than the volume of the forge can efficiently take so you have a surplus of fuel and not enough O2 to burn causing the large DB. It might be that solving problem 1 will allow you to not use the second burner meaning its not wasting fuel just to fight the heat loss of poor insulation. If it is the case of the forge being too small for the amount of burners you have putting on the ribbon might cause more problems as right now from what it sounds you are brute forcing your way through the heat loss/sinks of hard FB and the ribbon will do that but it will still be just as wasteful. Plus if you have a smaller than the minimum for the size of ribbon you have it means to run it with enough air to keep it cool with make it always be oxidizing but if you lower it to make it neutral it will overheat and backburn in the manifold which is bad. I made this mistake with my current forge as its just slightly too small so overheats the manifold if you aren't paying attention to it. Link to post Share on other sites
Jaro Petrina 34 Posted January 13 Author Share Posted January 13 (edited) This forge is 10X10X50 cm that is like 490 cubic inches. It has insulation behind the brick. But I m still gonna build a new one. Edited January 13 by Jaro Petrina Link to post Share on other sites
Wayne Coe 54 Posted January 13 Share Posted January 13 Check out the Build a Gas Forge and the Ribbon Burner attachments on the Forge Supplies page at www.WayneCoeArtistBlacksmith.com. Let me know if I can help you. About $100.00 plus the hose, regulator and burner using a 20# Propane tank. Link to post Share on other sites
Jaro Petrina 34 Posted January 13 Author Share Posted January 13 (edited) Wayne I have found and read the instructions, I know your page, thanks. I m far away, and as you remember our customs are pain in the arse - I bought some IR paint stuff from you, while ago, that works well actually, but it was difficult to explain to our official knobheads what it is and why I want it. Our propane tanks are different size, but a friend of mine is gonna roll me thick walled tube. Ill go further like this, the burner is 12X3" (in your units) the metal shell is about 14" diameter and 20" long. The inner space is gonna be 7" in diameter. The fiber insulation is not drawn here, only the hard lining. My blower is 1,1 HP and according the sticker it should do about 1800 m3/h which should be 105 cfm. Edited January 13 by Jaro Petrina just clarification Link to post Share on other sites
Jaro Petrina 34 Posted January 13 Author Share Posted January 13 The hardest part was to find refractory for lining. I have something called MSG-1 which is for working temperatures around 1400 C, but it has heat resistancy up to 1700 C and it can be improved by adding further compounds. I think if I mix around 10 kilos I can add some sandblasting AL2O3. Normally it has about 35% of it, but the instruction say, you can add whatever fillers up to some ammount. Link to post Share on other sites
