Darren Tee 1 Posted Thursday at 02:04 AM Share Posted Thursday at 02:04 AM Hi All, This is my first post. I am sure that as my son and I progress with this hobby there will be more posts. After reading lots on simple forges to heat treat blades we successfully built our first forge. Pictures below. We used a propane torch but I don't think that it is "big" enough. The heating chamber of this forge is very small - 2 1/2" x 9" x 4 1/4". I think that the Frosty T design would be too big. My question is there a smaller burner design out there, or is the Frosty T design OK for such a small forge? Many thanks, 1 Link to post Share on other sites
Cory LA 0 Posted Thursday at 03:29 AM Share Posted Thursday at 03:29 AM Fairly new myself, but...... I built mine with 6 bricks, so it's twice the width of yours but still pretty small. I used a 1/2" T burner and it works great. (It hits welding temps) I'm sure someone here can help you tune one to work perfect in yours. Link to post Share on other sites
Alan Longmire 2,632 Posted Thursday at 07:06 PM Share Posted Thursday at 07:06 PM Either the T-burner or a Ward reducer burner is perfect for that size forge. I prefer the Ward reducer just because it's easier to tune than a Frosty. A little more expensive to make, but you can get all the parts from High Temp Tools for $45 plus shipping. Or you could order a Black Beauty from Anvilfire.com at $50, ready to go. That might be a little overkill, but it won't hurt anything. Welcome aboard! Link to post Share on other sites
John N 262 Posted Thursday at 09:04 PM Share Posted Thursday at 09:04 PM Really neat looking build! - I cant advise on burners, but keep the end of the burner out of the forge chamber, or it will be eaten by the forge gods! For what its worth, all forges end up looking like sh!t after you have used them 6 times and modified them 6 times. Its all part of the process I don't ever want to be 'the safety guy' but if you start using propane burners (venturi or blown) invest $20 in a CO alarm. I have told a few people this in 'real life', and a couple have got back to me grateful, a bit shocked when they did, as the forge would have probably killed them! Welcome to the addiction Link to post Share on other sites
Darren Tee 1 Posted Thursday at 10:38 PM Author Share Posted Thursday at 10:38 PM 19 hours ago, Cory LA said: Fairly new myself, but...... I built mine with 6 bricks, so it's twice the width of yours but still pretty small. I used a 1/2" T burner and it works great. (It hits welding temps) I'm sure someone here can help you tune one to work perfect in yours. Do you have the specs for a 1/2" T burner? I can not find them online/ Thanks, Link to post Share on other sites
Alan Longmire 2,632 Posted Thursday at 10:53 PM Share Posted Thursday at 10:53 PM A 3/4" will be fine. Might have to slightly choke it, might not. Link to post Share on other sites
Cory LA 0 Posted yesterday at 01:50 AM Share Posted yesterday at 01:50 AM Darren, I'll look through my stuff and see if I can find the specs I started with. If I don't find them I'll get some measurements for you. As Alan said, a 3/4 will work, and if you decide to upsize your forge a bit you'll already have the burner. Link to post Share on other sites
Cory LA 0 Posted yesterday at 02:09 AM Share Posted yesterday at 02:09 AM (edited) 3 hours ago, Darren Tee said: Do you have the specs for a 1/2" T burner? I can not find them online/ Thanks, So I followed the original 3/4" directions, substituting 1/2" for all 3/4", using a .23 mig tip and mine ran best with a 5" mixing tube. Once you have it together you have to adjust jet and tube length for your forge. Remember not to have the tube sticking in past the forge wall. Edited yesterday at 02:10 AM by Cory LA Link to post Share on other sites
Darren Tee 1 Posted yesterday at 02:30 AM Author Share Posted yesterday at 02:30 AM Much thanks. Will try to figure this out. Ill keep you updated. Link to post Share on other sites
Gary LT 98 Posted yesterday at 03:37 AM Share Posted yesterday at 03:37 AM I have one as this for smaller blades, etc. and use a 1/2” stainless 6” nipple, 5” works also and 23 mig tip will feed enough air to gas mix to burn inside the chamber. I used a 1/2”, 3/4”, 3/4” tee. The nipple sets into a 1” floor flange with a 1” close coupled nipple in which I drilled and tapped screws to tighten and hold. (I stuff ceramic wool in the gap) This was put on the top panel at dead center. I used 1” ceramic wool everywhere else, coated with 1/4” satanite and then painted with ITC100. This setup allows more interior room than what you are gonna have. I used hard firebrick on the floor also coated with Satanite/ITC. The front opening is about 2 1/4” square and the back I left closed. You need to know that this burner placement will produce a hotspot but once the forge is at forging temps it’s not an issue. I easily get 1800 + degrees at 7 psi which is plenty for most all forging I do. I can control temperatures pretty easy and monitor temperatures with a thermocouple. I use a different forge for welding. Eventually the flange screws will deteriorate and the hinge will as well. Been using mine for 7-8 years, can’t remember! Gary LT Link to post Share on other sites
Darren Tee 1 Posted yesterday at 03:58 AM Author Share Posted yesterday at 03:58 AM I used 1 1/4" fire brick wrapped in 1/2" kayowool. The position of any burner will create a hot spot - no? Should you close the small gap around the hole where the burner goes into the forge? This is currently planned just for heat treating. If the bug bites hard we may try some welding but not just yet. Baby steps. Link to post Share on other sites
Wayne Coe 54 Posted yesterday at 11:24 AM Share Posted yesterday at 11:24 AM Fire brick will not last long and are a heat sink. Check out the Build a Gas Forge and the Ribbon Burner attachments on the Forge Supplies page at www.WayneCoeArtistBlacksmith.com. Let me know if I can help you. About $100.00 plus the hose, regulator and burner using a 20# Propane tank. Link to post Share on other sites
Daniel W 82 Posted yesterday at 03:46 PM Share Posted yesterday at 03:46 PM That is a really nice compact idea for a forge, and probably an overall good size! Hot spots, I think with your design of having that burner come in from the side, you will not notice it. I look for a hot spot at times, but I'm not as much a knife maker. I'm usually looking to make a swirly thing and sometimes everything hot is problematic. I would add to John N's suggestion of 20 bucks for a CO alarm, and say if you can get one with a digital read out even better. Typical CO alarms go off around 30ppm, but the digital ones can give you a read out of lower levels. Read the instructions that come with it. Biggest thing is to ventilate your working space with the forge as much as possible. Link to post Share on other sites
Darren Tee 1 Posted yesterday at 05:18 PM Author Share Posted yesterday at 05:18 PM 5 hours ago, Wayne Coe said: Fire brick will not last long and are a heat sink. I used thermal insulating fire brick rated up to 2600 degrees. Sorry if I wasn't clear - its not Home Depot fire brick. Link to post Share on other sites
Darren Tee 1 Posted yesterday at 05:31 PM Author Share Posted yesterday at 05:31 PM 1 hour ago, Daniel W said: Hot spots, I think with your design of having that burner come in from the side, you will not notice it. My though was that if the flame comes from the top it is directly impacting the work (creating a hot spot), while if it comes in from the side, and the work is on the bottom of the forge it wont be directly impacted by the flame. But, admittedly, I know nothing about doing this so I will learn and the burner location may change. Link to post Share on other sites
Alan Longmire 2,632 Posted 20 hours ago Share Posted 20 hours ago Side entry is good. You are correct, top-entry burners make the flame impinge directly on the work, creating not only a hot spot, but potentially an oxidizing spot if your burner is not properly tuned. This leads to heavy scale and decarburization. I think a lot of commercial forges do this because the makers don't know or care about how gas forges are supposed to work, which is to heat the lining which then heats the steel. In a larger forge you can get an absolutely even heat by having a cylindrical chamber and letting the burner enter the chamber at a tangent to set up a swirling flame. These little forges are hard to do that with, though. As Daniel points out, it's also nice to have a hot spot for some operations. There's advantages and disadvantages to everything. Link to post Share on other sites
