Einar 53 Posted January 25 Share Posted January 25 14 cm blade, 27 cm overall. 4.3 mm thick Silver steel (115CrV3) blade 60HRC Beech burl handle scales with stainless steel pins A present for my workmate Simon. No hand sanding on this blade. Just 120 grit belt finish straight off the belt grinder. 6 Link to post Share on other sites
clint c 129 Posted January 28 Share Posted January 28 That looks great, excellent design. What size wheel did you use for that grind? Clint Link to post Share on other sites
Doug Lester 280 Posted January 29 Share Posted January 29 Outstanding knife. I'm sure that your workmate will be thrilled. Doug Link to post Share on other sites
Einar 53 Posted January 31 Author Share Posted January 31 On 1/28/2021 at 9:30 PM, clint c said: That looks great, excellent design. What size wheel did you use for that grind? Clint Its a flat grind. It does look like a hollow grind in the pics, but thats a trick of the light. On 1/29/2021 at 4:01 AM, Doug Lester said: Outstanding knife. I'm sure that your workmate will be thrilled. Doug Thanks, we'll see on monday Link to post Share on other sites
