SS tube for canister
Geoff Keyes
Has anyone tried this?  If so, do you use a release agent or not?
I said that.
- - -G. K. Chesterton
Grant Sarver
I saw a demo once of using SS exhaust pipe as cannister.  He used a sheet of newspaper.  He also said you can use aluminized exhaust header tubing with no release agent, sine the aluminizing makes it nonstick.
1 hour ago, Kreg Whitehead said:
Or maybe tossing a regular can in the forge a few times to get some scale built up....just thinking out loud.
I was wondering about this same thing.  Would that work, or would the oxides get reduced back into steel in the low oxygen environment?
-Brian
