Playing with file work
Joshua States
Most of you know that I really like doing file work on my handles. File work doesn't have to be complex or ornate to achieve a dramatic effect. Sometimes quite simple things can look just as eye catching as the more robust patterns. The foundation of any patterned file work is in the layout. This must be consistent and symmetrical along the length of the work piece. Here you can see the three starter lines to provide a border and the tick marks along both edges. The diagonal lines are cut with a jeweler's saw.
You need really good task lighting, some magnifying eyewear, and something to hold the workpiece very stable.
You have to reposition the workpiece several time in order the get the same angle on each cut.
if the pattern uses multiple files for different angles in a stepped process, complete the first step on the whole piece before moving to the next tool. Sometimes it help to clean the piece off and inspect the work as well.
When you think you have it done, assemble the handle parts and check the look. You may have to make some adjustments.
The 3-piece spacer for this knife has a very simple looking pattern. It is a deceptive simplicity though. This requires absolute symmetry. As each piece gets done individually, the package must be assembled frequently to check the form.
  • Like 6
Thanks Alan, but it was really meant to show folks that they don't have to get heavily involved with patterns like rope and vine or even S pattern to start out.
Those patterns take multiple files and compound cutting angles.
These simpler geometric styles are technically "simple". They just rely heavily on consistency in the layout to achieve the effect. The above pattern takes a jeweler's saw and a modified margin file. This pattern takes a jeweler's saw and a small round file. All straight cuts.
The pattern on the spacer package take a triangle file and a margin file.
Still, it would be a shame to stop there; nudge-nudge, wink-wink, know what I mean? Say no more...;)
