Coffin Frame Dagger Build
Joshua States
Chubby?!?! OK, now I'm laughing. As I said earlier, I am considering fluting this handle. I bought a video course by Kyle Royer on handle fluting (I highly recommend this) and I really want to try it out on something. I did a little sketch work today.
  • Like 3
2 hours ago, Alan Longmire said:
That'll do! :lol:
The pomell looks too small. I'll have to do something there.
I feel the handle could use more swell toward the guard and taper into to pommel rather than swell in middle however fluted takes away the “chubby” appearance. I have no clue how this could affect fluting.
(like I could even attempt to do anything close too this!)
Gary LT
I have been looking at the shapes and profiles of fluted dagger handles for some time now. It has been on my "to-do" list ever since I learned about the ABS test criteria, and that was many moons ago.....
When you start to realize that there is no "correct" shape to these, you loose the constraints and open up the possibilities. Some are flatter on the sides, some are more rounded. They all have some sort of double taper along the handle edges. Whether that taper is longer from the swell to the pommel or longer from the swell to the quillon, seems to be a maker's choice sort of thing.
I have seen some that have a prounounced swell towards the front spacer and a very long taper towards the pomelll. MS Steve Culver does this quite often, whereas MS Kyle Royer puts the swell more toward the center.
I will play around with moving the swell forward and see what I think. Thanks for the suggestion.
I hand sanded the fullers out to 320 yesterday.
Today was a forge day for me and I worked on 4 Damascus bars and a chunk of 1095. (Stay tuned for more stuff in that lecture on Damascus thread). One of the bars is a bold and lower layer twisted bar for the fittings on this dagger.
So here is the idea. If I can pull this off, I will be very happy.
Here is the twisted bar. It was about 5/8" square before twisting. I did smack down the corners a little and made it a little tighter after this pic was taken.
I partially requared it, spread and flattened a portion. This is now a little wider than 1" and about .27" thick.
The back portion is still square(ish) and will become the pommel in a 4-way stack.
On your marks........
Get set!..........
Switch to plan B......
Back at it today after prepping a new twisted bar last weekend. This was some delicate forging using the O/A torch and a number of bicks, small anvils, and a guillotine fuller.
I fit it to the blade and decided I needed to reduce the straight portion.
Starting to make the curves.
  • Like 3
Minor progress, and I'm not sure I like this at all. I finished the forging on the guard.
Then I made and fit the 5-piece spacer package. Two twist Damascus plates and three .04" nickel-silver plates.
  • Like 3
Awesome work! Love the fuller. Looking forward to seeing it done!
http://stephensforge.com
Thanks man. You have been one of those makers whose work always inspires me. I have a couple of commissions I need to get to work on and this is a side project now, so it will move off the current bench onto the on-deck bench for a bit.
Great to see you and everyone else still in the fight. I've been so tangled up in keeping the company afloat due to Covid I haven't put hammer to anvil in a very long time. Feel like I'm losing a part of my soul. Thanks for the inspiration.
  • 9 months later...
Well, this has been sitting on the bench craving some attention for a while. Every attempt I have made at forging the ring hilt out of a single piece has produced more Damascus scap than I care to acknowledge. That will now have to wait until I get more steel to make new billets. In the meanwhile, I have redesigned the whole thing around the blade.
It is now a frame handle design. I may still try and put a ring on the guard or attach a Nagel sort of thing following the coffin shape motif. We will see how that works out. Here is the new handle design.
For those of you unfamiliar with the frame handle process, I have posted a separate thread with all the steps.
This will show a shortened version.
The actual frame is twist Damascus with some nickel-silver liners. This is different fom the previous method in that I am starting with a 2-piece construction. I take a flattened, twisted bar and split it in half. The hole is drilled where the bar needs to be bent to accomodate the turn in the handle profile.
These are then surfaced again, laid onto the piece of 1/4" MDF board.
and arranged under the template for drilling.
The liners are done in the same manner as in the How I do Them post.
After dilling and removing the excess, the finished frame and liners are now ready for the scales.
  • 3 weeks later...
This weekend I managed to fit the handle scales, rough shape the guard, HT the fittings, and profile the handle to 400 grit. Later this week, I will shape the handle and etch the frame and spacers.
The fittings after HT.
Dry fit the handle with spacer package
Dry fit the handle with the guard
I really need to pay more attention to what is behind the subject in the photo. That old sock sticking out of the orange bucket isn't doing me any favors here.
  • Like 3
  • Joshua States changed the title to Coffin Frame Dagger Build
Dang dude, this is awesome.
Ha, when I first saw that pic, I thought "There is no way Joshua would be that far off on even a dry fit-up" so I had to look closer to see that the background was blending in with the handle.  You got the benefit of the doubt though :)
  • Haha 1
-Brian
So the handle got shaped. I may still thin it down a little more though. The finial got turned and groud down to resemble the coffin shape. (a butt strike will be like getting stabbed with a flat head screwdriver). The tang extension got threaded and everything fits together nicely.
Side view
Full shot
I etched all the pieces parts yesterday which was almost catastrophic. (note to self: remember to check the threaded rod used is really the stainless steel one and not the zinc plated one) I have to re-etch the guard again due to some minor zinc plating......
Now I will file work the liners.
