Andrew Gillespie 6 Posted July 29, 2021 Share Posted July 29, 2021 What temperature do I use for 1075 for normalising, hardening and tempering? Link to post Share on other sites
Alan Longmire 3,783 Posted July 29, 2021 Share Posted July 29, 2021 What is your heating setup? Just a forge, or do you have a kiln? And if a forge, gas or solid fuel? How are you judging temperature, in other words? 1075 is one of the easiest steels to heat treat, since it's right at the eutectoid point with reference to the iron/carbon phase diagrams and it has no other carbide-forming elements. This means no soaking needed, as there are no big carbides to break up or distribute. Your only variable is manganese, which ranges from 0.4% on the low side (the maximum recommended for good hamon) to around 0.8% on the high side (deeper hardening). If you're using a forge with no thermocouple, watch for decalescence as always. If you have a way to accurately measure temperature, normalize by heating to 885 C/ 1625 F and cool to black in still air. You can do descending heats down to 815C/1500F. Harden by heating to 815C/1500F and do not soak, quench immediately in warm oil for thicknesses below 6.5mm or so. Thicker sections may need water or brine. Temper immediately for at least two one-hour cycles. Depending on intended use, temper at anywhere between 163C/325F to 232C/450F. I'd go with 163C for a fine slicer, 175-200C for a general chopper/EDC. 3 Link to post Share on other sites
Andrew Gillespie 6 Posted July 30, 2021 Author Share Posted July 30, 2021 Thanks! I use an electric kiln with thermocouple. I only do stock removal. This particular knife is 3mm thick and meant to be a fine slicer. I will try: normalize 885 C, heat to 815 C and quench in 40 C oil and then 2 one hour cycles at 163 C. Link to post Share on other sites
Alan Longmire 3,783 Posted July 30, 2021 Share Posted July 30, 2021 Since you're doing stock removal only, you may want to normalize two or three times to refine the grain. The raw barstock is probably spheroidized annealed, and the grain will be on the large side. 1 Link to post Share on other sites
Andrew Gillespie 6 Posted July 30, 2021 Author Share Posted July 30, 2021 Thanks, I will do so. Link to post Share on other sites
Andrew Gillespie 6 Posted August 3, 2021 Author Share Posted August 3, 2021 I messed up, the piece curved. I am not totally sure why, but I was cooling it outside the furnace between heating. I think that it might have cooled faster on one side. Is there any good way to straighten it? Link to post Share on other sites
Alan Longmire 3,783 Posted August 3, 2021 Share Posted August 3, 2021 Since it's not hardened yet, just bend it back straight. Hot or cold. If you do it hot it reduces the chance of it warping again. Did you put it down while it was cooling? Link to post Share on other sites
Andrew Gillespie 6 Posted August 3, 2021 Author Share Posted August 3, 2021 I didn't put it down, I hung it with a wire hook through a hole drilled into the handle section. I will try the straightening hot, hopefully I will get it right. Link to post Share on other sites
Gerhard Gerber 469 Posted August 3, 2021 Share Posted August 3, 2021 On 7/30/2021 at 1:36 PM, Alan Longmire said: Since you're doing stock removal only, you may want to normalize two or three times to refine the grain. The raw barstock is probably spheroidized annealed, and the grain will be on the large side. This.......I did not know. Not unhappy with my 1070 results, but if it could be better..... Link to post Share on other sites
Alan Longmire 3,783 Posted August 3, 2021 Share Posted August 3, 2021 Hmm... So, uneven cooling somehow. Is it a thick chisel grind? Those can make interesting warps... 3 hours ago, Gerhard Gerber said: This.......I did not know. Not unhappy with my 1070 results, but if it could be better..... For any low-alloy steel a normalizing cycle or two before hardening can't hurt. If you're using your kiln, be sure to protect against decarburization. Link to post Share on other sites
billyO 411 Posted August 3, 2021 Share Posted August 3, 2021 (edited) I was just looking this info up for a friend, so I thought I'd add what Dr Larrin Thomas says in his book Knife Engineering: Recommended normalizing temp for 1075 - 1525F. But he does say "It is better to use a relatively high temperature to normalize, followed by 1-2 grain refinement steps at a single lower temperature optimized for grain size." Earlier in the chapter he says that the normalizing temperatures he recommends are generally the "minimum" temps, and "As much as 100F higher than the recommended temperature in the table is probably reasonable." He also writes: - "the 'descending' temperature cycling method does not really help with the goal of grain refinement." and "1450F is a safe grain refining temperature for most low alloy knife steels." For hardening, his recommendation for 1075 is 1475F for 10 minutes, fast oil quench, temper at 350F-400F. Edited August 3, 2021 by billyO RIP Bear....be free! as always peace and love billyO Link to post Share on other sites
Gerhard Gerber 469 Posted August 5, 2021 Share Posted August 5, 2021 On 8/3/2021 at 8:09 PM, Alan Longmire said: Hmm... So, uneven cooling somehow. Is it a thick chisel grind? Those can make interesting warps... For any low-alloy steel a normalizing cycle or two before hardening can't hurt. If you're using your kiln, be sure to protect against decarburization. I was wondering about that..... I have a roll of stainless foil, but its expensive and difficult to get more, so I use it only for stainless Link to post Share on other sites
Charles dP 589 Posted August 5, 2021 Share Posted August 5, 2021 Still not enough caffeine to employ all my neurons but I seem to remember an old thread where people were experimenting with making home-made anti-scaling compound which I believe stops decarb (did anyone ever manage to make a good one?). @Joshua States, will the titanium oxide white paint stop decarb too? "The way we win matters" (Ender Wiggins) Orson Scott Card Nos, qui libertate donati sumus, nes cimus quid constet. Link to post Share on other sites
Andrew Gillespie 6 Posted August 5, 2021 Author Share Posted August 5, 2021 I wish I could buy the commercial anti-scale, but I can't find anyone who sells it. My attempt at using boric acid was not 100% but it helped a little. I'm wondering if I applied it unevenly causing one side to cool at a slower rate. Link to post Share on other sites
Alan Longmire 3,783 Posted August 5, 2021 Share Posted August 5, 2021 Time to get creative, then. Start with finely powdered charcoal and clay, and try to find a binder like molasses or cider dregs. That's not too far from Theophilus' recipe from 1100 AD or so. Adjust quantities to get a stiff dry paste. Use as thin a coat as you can. Maybe add some borax or boric acid. 1 Link to post Share on other sites
Joshua States 2,502 Posted August 6, 2021 Share Posted August 6, 2021 17 hours ago, Charles dP said: will the titanium oxide white paint stop decarb too? Yes it does. This is what I use. Works great. 2 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Eric Morgan 175 Posted August 7, 2021 Share Posted August 7, 2021 I wonder if a wash of titanium dioxide would have the same effect… I can get loads of the stuff from work for nothing. Link to post Share on other sites
Joshua States 2,502 Posted August 7, 2021 Share Posted August 7, 2021 1 hour ago, Eric Morgan said: I wonder if a wash of titanium dioxide would have the same effect… I can get loads of the stuff from work for nothing. Just figure out a way to put it into a solution that will stick to the metal “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Eric Morgan 175 Posted August 7, 2021 Share Posted August 7, 2021 51 minutes ago, Joshua States said: Just figure out a way to put it into a solution that will stick to the metal I’ll get some this weekend and give it a go when I get a chance Link to post Share on other sites
Andrew Gillespie 6 Posted August 10, 2021 Author Share Posted August 10, 2021 I read that carbon will damage the heating elements in an electric kiln. Is that true? Link to post Share on other sites
Jerrod Miller 595 Posted August 10, 2021 Share Posted August 10, 2021 7 hours ago, Andrew Gillespie said: I read that carbon will damage the heating elements in an electric kiln. Is that true? It can, depending on the material of the elements. Link to post Share on other sites
Andrew Gillespie 6 Posted September 16, 2021 Author Share Posted September 16, 2021 I managed to get hold of an anti-scale Consursal Z1100 which is a german product. Works well, but is very expensive. Link to post Share on other sites
Andrew Gillespie 6 Posted September 23, 2021 Author Share Posted September 23, 2021 I continued experiments with boric acid out of curiosity. I am now convinced that it cannot work for steel as it becomes too corrosive at the temperatures needed for steel. Rather leave it for the jewellers working with precious metals and lower temperatures. Link to post Share on other sites
Gerhard Gerber 469 Posted January 11 Share Posted January 11 On 8/5/2021 at 11:20 AM, Gerhard Gerber said: I was wondering about that..... I have a roll of stainless foil, but its expensive and difficult to get more, so I use it only for stainless This has been bothering me, especially since I just got some more 1070 and one piece of 1084. Foil situation is unchanged, difficult to get and expensive, reserved for stainless, more so because I hope to get a piece of Elmax in the near future. So I was thinking, I have the gas forge, even if I'm guessing temperature, as long as I don't completely cook the blades they could benefit from a few normalizing cycles before HT in the electric kiln? Link to post Share on other sites
Alan Longmire 3,783 Posted January 11 Share Posted January 11 I'm going to say yes. They certainly could. Is there anything you can mix up as anti-scale compound? Something as simple as half refractory clay and half charcoal powder will work, as long as it stays on the blade until it hits the quench. A paper thin layer is enough. Mix with just enough water so you can smear it on. Link to post Share on other sites
