Gerhard Gerber Posted January 11, 2022 Share Posted January 11, 2022 Do you mean some anti-scale compound so I can normalize in the kiln? I don't have any refractory cement, and I'm careful about what I put in the kiln because I can't afford to replace it. I try to get at least 2 uses out of each foil envelopes, so I considered using one of those for the 1070 blades, but I mostly make hunting knives in stainless and chef's knives in 1070, so the envelops are too small. Link to comment Share on other sites More sharing options...
Alan Longmire Posted January 11, 2022 Share Posted January 11, 2022 No, I meant in the forge. I agree about putting odd things in the kiln. If you have some protective atmosphere in the forge you can do all the pre-quenching heat treat steps with no worries about decarb. 1 Link to comment Share on other sites More sharing options...
Gerhard Gerber Posted January 12, 2022 Share Posted January 12, 2022 (edited) Chicken & egg situation, if I could get my new burners working I could build the new forge with the proper bricks I acquired nearly 2 years ago and stick a pipe in there..... Been thinking about this a lot seeing the price of kilns, before I've imported it.... Shouldn't say this out loud, but I'm pretty sure I got lucky a few times and did a better HT with a pipe in the forge than with the accurate kiln, specifically carbon steel blades......way less decarb. I have a small container of something that might be water damaged refractory cement, I could never get it to set into anything usable so I might as well try the mix you suggested, can't hurt and no loss Edited January 12, 2022 by Gerhard Gerber grammer Link to comment Share on other sites More sharing options...
Alan Longmire Posted January 12, 2022 Share Posted January 12, 2022 Certainly worth a shot. Use a coat thin as paint. Link to comment Share on other sites More sharing options...
Doug Lester Posted May 9, 2022 Share Posted May 9, 2022 Is Parks #50 the preferred quenchant for 1075? Doug HELP...I'm a twenty year old trapped in the body of an old man!!! Link to comment Share on other sites More sharing options...
Alan Longmire Posted May 9, 2022 Share Posted May 9, 2022 If it's the NJSB low-Mn 1075, yes. That or water/brine, it was developed for hamon. If it's Admiral or other high-Mn 1075, no. Canola or a medium oil is better. Link to comment Share on other sites More sharing options...
Randy Griffin Posted May 11, 2022 Share Posted May 11, 2022 I have a piece of 1075 from NJSB so when I use it I will need to quench in water to get the most out of the steel? Link to comment Share on other sites More sharing options...
Alan Longmire Posted May 11, 2022 Share Posted May 11, 2022 No, canola is fine. Only use water if you want really active hamon or if it's really thick in section, like a hammer. 1 Link to comment Share on other sites More sharing options...
Gerhard Gerber Posted June 10, 2022 Share Posted June 10, 2022 I now have 1070, 1084 and 80CRV2 in thin bar stock suitable for kitchen knives. The recommendation here is bar stock like that needs to be normalized as well, currently I just grind and heat treat. I will still try the old refractory cement as anti-scale, but I have serious doubts I can get the stuff to bind. So I had a thought, what if I profile the blade, normalize, grind the bevels and then heat treat? Link to comment Share on other sites More sharing options...
Alan Longmire Posted June 10, 2022 Share Posted June 10, 2022 5 hours ago, Gerhard Gerber said: what if I profile the blade, normalize, grind the bevels and then heat treat? That will work fine. I'd throw one more normalizing cycle in after the grind just to relieve any uneven stresses from the grind. 1 Link to comment Share on other sites More sharing options...
Bjorn Gylfason Posted July 14, 2022 Share Posted July 14, 2022 I'm wondering if anyone has experience with this thing I'm pondering. I have a pretty long blade forged from 1075 and am more concerned with toughness than absolute hardness. Would quenching it in medium speed oil help any with that or should I use the fast one and just temper it back? Link to comment Share on other sites More sharing options...
Alan Longmire Posted July 14, 2022 Share Posted July 14, 2022 Use the fast oil and temper it back. The finer structure is tougher. 1 Link to comment Share on other sites More sharing options...
