Angle grinder stone flywheel for flattening hard anvils?
Yo,
I'm wondering how flat these angle grinder pot shaped stone attachments grind surfaces.
I got a hard anvil that needs a bit of flattening due to hardening and welding distortion.
It has some flat spots I can use, so I'm a bit reluctant to try and potentially ruin it with an angle grinder stone wheel thingy.
What's it called in English?
47 minutes ago, Alan Longmire said:
Cup wheel.  They are very aggressive, but in skilled hands they do a good job.
Aight, as long as it's not terrible, I'm willing to give it a try.
You can try a flap disc, too. Not quite as flat, but much less aggressive. To make sure you're touching the right spots, you can coat the anvil face with Dykem and rub a small surface plate/wide, flat piece of steel on it. Wherever the Dykem was rubbed off, that's where you have a high spot.
Yaah, I tried flap disks and files and stones...buut thats still a bit too inconsistent, and the flat disk is too aggressive.
I hone my anvils with whetstones but pointless to do with how slightly warped it is.
This was with flap disk and stone.
I got a usable flat section for small knives and plane blades but if I tried to straighten saws or wider knives, that section probably is too small.
I've always found it easier to straighten things on a not-flat surface.  A slight valley gives a good spot to add counterbend to allow for spring-back.
I like a sanding disc for more control than a flap wheel:
For general straightening I use a wood anvil. This anvil is supposed to be for fine/final adjustments and checking, especially for tools that need precision.
Tried those, they were terrible, almost immediately lost grit and or ground themselves up.
Maybe there are better ones?
I get Gator brand discs and the seem to hold up well.
