Odd whetstones
Joshua States
OK Hivemind. I need some help identifying this whetstone I have had for some years. Purple on one side, yellow on the other. Both fairly soft. Any ideas?
Several notabe smiths on FB tell me the purple is nothing but a backing for the yellow stone. The yellow stone is supposedly Belgian Coticule, 8000 grit water stone.
It's about the right size and shape for a barber's hone, but I don't think I've ever seen one backed like that.  Is that a notch in the yellow that goes all the way across?  If so. I'd bet it is a barber's hone that cracked so somebody bonded it to a backer to keep using it.
-Brian
What I thought at first as well. After someone told me the purple one was probably a piece of slate backer, or (if I was really lucky) a Belgian Blue Stone, I started looking on line. I found this: https://www.bestsharpeningstones.com/category_details.php?category_id=74
It does look like one of the belgian stones, I have a small double sided one, but on mine the blue stone is more of a grayish blue than purple.
The coticule are fairly soft, but not really friable if that makes sense.
They are also very high grit and leave a fine polish and really sharp edge.
If it is an belgian you are lucky becuase they are quite expensive in those sizes
