Pocket Parang
parsha
Hi Folks,
Working on a very small version of a parang made from a piece of truck leaf spring.
I am thinking of a 3.5 inch cutting edge and a long ricasso which I am thinking will give good forward weight to such a small blade .
Aiming for OAL of 9 inches. Need advice about how to shape the tang give it a good downward curve or keep it straight at an angle where the ricasso ends at the handle. Also looking for suggestions about overall design. I am thinking a peened wooden handle should be nice . Right now it is at 8 inches OAL and will be drawing out the tang a little more
No ideas but watching...
https://en.wikipedia.org/wiki/Parang_(knife)
 His Parang is more the style of the second one!
Like the machete, the parang is frequently used in the jungle as well as being a tool for making housing, furniture, and tools. The parang has been noted in John "Lofty" Wiseman's SAS Survival Handbook[3] for this use. Wiseman points out that by grinding three different angles in three separate regions along the Parang blade—a narrow angle at the tip for skinning and fine cutting work; a wide, chopping blade angle along the bow in the blade for ax work, and an all-purpose hunting/survival knife angle along the edge nearest the handle for general purpose work—the parang becomes a very useful, and compact all-purpose tool in the bush.
Parang are recorded being used in attacks against the British and Japanese. They are typically carried as weapons by gang members and robbers in Malaysia, Singapore, India, and Sri Lanka, due to these countries having strict gun laws.
Parangs were used by Chinese forces against the Japanese in the Jesselton Revolt during the Japanese occupation of British Borneo.[4][5]
The only reason I had an idea of what he was talking about I remember an episode of FIF. At least I think that is where the Parang jumped into my vocabulary!! shoulder shrug.jpg
As to a pocket parang! I am not sure what he means there!
Edited by C Craft
Even I am not sure if I should call it "pocket parang" ;)
What I am looking to make is something similar to Greber pack axe in weight and size but shaped like a parang . Normally I haven't seen a parang less than 7 inches long blade. Basically a small size tool but with more chopping power than a normal 3.5 inch blade bushcraft or edc knife.
Let's see how it goes
Made a slight change and straightened the tang . Basically moved the hump in the tang a bit more closer to the blade than before.  Also widened the blade portion a little. Will be doing an edge quench in water20211016_132623.jpg
Can't help with the shape, but I strongly recommend against a water quench on truck spring.  It can be done, carefully, with lots of quick interrupted dips of the edge, but that steel is probably something like 5160 and that really prefers a slower quench.  Even when just edge-quenching.
Sure Alan. Will take that advice and quench in vegetable oil instead. As it is I have already forged the edge almost to final thickness.
I have seen several khukri making videos in which the kami carefully pours a stream of hot water on the edge to harden but I guess they have perfected the method by years of practice .
So oil is the way to go for me :D
Edited by parsha
I'm not a parang expert, I've seen the Condor Village parang, and my one attempt at making one turned out a bit beefy.
I can see that design, similar to the one example above, scale down to knife size successfully.
Forget about it ever chopping, make a knife that just looks like a parang.
If you'll excuse me, at this stage your design looks like it's trying to stay a chopper.
Do I call this a good heat treat? Blew off pretty much all of the scale on the edge after rubbing it with a scotch brite pad.
Tested with a file and the file skates off without biting at all. On to the tempering light straw/ dark straw at the edge?
Looks like it hardened!  As for temper, light straw for slicing, dark for chopping.  Make sure there is no oil or fingerprints on the edge, that will throw the colors way off.  As in, you can see full blue and it may still be too hard to file.
Which is why using temper colors is a bad idea.  Thermometers and ovens are cheap.
You all knew I would have to chime in and say it.
  • Haha 3
Unfortunately I don't have access to a temperature controlled oven now.
A good long soak in warm soap water followed by brushing with scotch  brite wheel on an angle grinder should get rid of all the oil.
