Removing gflex epoxy
Paul Checa
Hi all,
So I screwed up and dinged the blade when polishing the handle and now it has a mark over the ceramic Coating. I need to remove the handle without damaging it (preferably) so I can glue it back again. It's carbon fiber.
Any ideas?
Thanks,
You can try acetone.  It will soften GFlex, but it may also affect the CF.  Aside from that, I've never successfully removed a handle secured with GFlex.
g
I said that.
- - -G. K. Chesterton
Grant Sarver
