Problems making a chef's knife
6 minutes ago, Conan Dunlap said:
ATP 641
It works very well. I use it on every knife I make.
There's also the new trend of using wax. It apparently does the same as ATP, but I didn't try it yet.
10 minutes ago, Alex Middleton said:
@Joël Mercier, you've peaked my interest.  I haven't heard of that before.  Any specifics, or just a coat of generic wax?
So far I've seen 3 makers using butcher's and carnauba wax with excellent results. Still, I remain sceptical until I try it myself.
3 hours ago, Conan Dunlap said:
Does anyone have any experience with the Brownells ATP 641 anti-scale coating?
I, too, use this, and no problems hardening  if it's applied thinly.
3 hours ago, Joël Mercier said:
There's also the new trend of using wax . . .using butcher's and carnauba wax with excellent results
How does the wax not burn up at 1475F?
Edited by billyO
Edited by billyO
It does and it supposedly leaves a film that protects the blade.
1 hour ago, Alex Middleton said:
Heck, I'll try it next time I'm heat treating.  I don't have any ATP-641...............:ph34r:
Great, keep us posted
46 minutes ago, Alan Longmire said:
I have a block of pure carnauba from when I made pipes.  It's more expensive than atp-641. ;)
Yeah, I got a block too....and 1.5 pint of ATP. I don't plan on trying the wax until I'm through with the ATP, but it'd fun if someone here tried it, for prosperity :D
I still have a quart of Kilz acryic primer........
How do you keep the wax from getting all over the bottom of the oven? Heat it in a baking pan? Then you either get wax floating in your quenchant, or on your quench plates.
The whole idea sounds messy to me.
The wax completely burns...
Which makes me wonder even more how this is an effective anti-scale coating. Much too much thinking for my little brain......
I would speculate that the thought is as it burns it leaves a carbon layer that will counteract the decarb.  In which case one could probably just put a soot layer over the blade via a candle.  I don't use anything for anti-scale, so I can't confirm the performance for anything.
