Not a messer for a change but a bowie wip
Bjorn Gylfason
There's a makers challenge on the book of faces that got me out of my messer dominated dreamland :lol:
Started by going to the ever growing pile of half hammered things I forget about and found a suitably sizes piece
drew out a tang and shape a bit and then ground bevels. I usually like fully sanded surfaces but wanted to see how an as forged finish would look
I've never really bothered with getting perfectly square shoulders as I find it a lot less frustrating to file the bolster to shape :rolleyes:
Walnut grip drilled and then burned onto the tang
Decided to add a little spacer behind the guard as it all felt a bit flat
Then a little bit of filing to make the brass more interesting
Peen everything! :lol:
Now I do like shiny brass but it didn't really look right on this knife. just a few drops of ammonia into the bottom of a container that I then hung the knife over and sealed did a wonderful job in a couple of hours to get this much better looking patina
260726116_10161336288872437_3511698764982107519_n.jpg261337902_10161336289102437_453728461822275846_n.jpg260846797_10161336289307437_2379557561696622528_n.jpg
Then it was time to make a sheath. the plan is a double layered leather sheath with a brass locket that might look pretty neat if it comes anything close to the vague idea in my mind
Inner layer cut out and overlapping edges skived down
Blade is oiled and then cling wrapped followed by a layer of electrical tape, that seems to give just about the right amount of extra room around the blade for a snug fit once the whole sheath is sewn up and dried.
Then I mould the leather around the blade and wrap it tight with cord to dry over night
262348240_10161344358142437_1582635666632531025_n.jpg262418156_10161344358202437_2401713950750832317_n.jpg
For extra stiffness I then glued on two layers of 0,3 mm plywood on the front side of the inner layer.
That is now drying overnight and we'll see how it progresses in the morning
  • Like 6
Looking very "moutain man" . Where was this maker's challenge?
4 hours ago, Bjorn Gylfason said:
Over on 'the art of weapons' group
I wonder if I could use one that is already made and documented......
What? No chape? B)
Looks cool Bjorn.
