Bjorn Gylfason 618 Posted February 6 Author Share Posted February 6 Today was mostly spent filing the crossguard. Will sand away the majority of the file marks tomorrow and brass it. Then I think I should begin on the grip parts 3 Link to post Share on other sites
Joshua States 2,566 Posted February 7 Share Posted February 7 Looking good Bjorn. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Francis Gastellu 273 Posted February 7 Share Posted February 7 Very nice progress, and I'm loving this thread! Link to post Share on other sites
Bjorn Gylfason 618 Posted February 7 Author Share Posted February 7 Well, got the guard brassed Then after filing a little bit more on the tang to get the pommel closer to it's right place I cut down some ziricote for the grip and here is where it will deviate from the original. The guy already owns a rondel dagger from me and wanted the grip to be in the same style. That is fluted in two parts with a brass spacer. That will also warrant some slightly different ferrules to better fit that look. Good thing with shorter pieces is that drilling and filing the slots is easier but on the other hand they have to fit much closer to prevent any wiggle and of course mate to that many more surfaces. And got it mostly roughed in on the belt grinder though I still need to thin it down some more and decide wether I will undercut the ends of the wood for the ferrules to sit into 4 Link to post Share on other sites
Bjorn Gylfason 618 Posted February 10 Author Share Posted February 10 Filed down each end so the ferrules should sit semi flush with the flutes but we'll see how that turns out Cut down strips of brass and shaped them so that they are a tight fit on the narrower end of the recesses with the thinking I'll then stretch them out into a more conical shape I'm really enjoying silver brazing if anyone hadn't noticed And as they sit right now after very slight stretching Then decided it might be a good idea to get the flutes started to better figure out how I'll be blending the ferrules into the whole look Guide lines are done without any measurements as the idea is to get that medieval non perfect perfection but having them still helps a lot High tech filing station and I really have to have a word with whoever is supposed to keep things clean and organized in the workshop. I feel it's easiest to get the lines started with a round file and then switch over to the square one to get them deeper and narrower And then I realized I could just as well do the rounding over in the comfort of the living room It's coming along slowly but surely 4 Link to post Share on other sites
Bjorn Gylfason 618 Posted February 10 Author Share Posted February 10 Got all the parts fitted together the ferrules feel a bit plain but I'll think about what I'll do with them while I get the leather on the scabbard One interesting thing is just how small and short the grip is even though it is a few millimeters longer than the original. I can't grip it securely right now as all the parts are loose but it feels like it's made to finger the guard. Holding it that way feels natural and the shapes of the guard make it very comfortable 2 Link to post Share on other sites
Brian Dougherty 1,421 Posted February 10 Share Posted February 10 Dang this is looking good. Did you do the brassing by heating it and going after it with a brass brush? It looks very consistent. -Brian Link to post Share on other sites
Bjorn Gylfason 618 Posted February 10 Author Share Posted February 10 1 hour ago, Brian Dougherty said: Dang this is looking good. Did you do the brassing by heating it and going after it with a brass brush? It looks very consistent. yes, heat and a brass wire wheel on the cordless drill. Doing a couple of passes to make sure everything gets covered does make it consisten but right now it has a bit of a rattle can look that isn't very pleasing to my eyes so before everything gets peened I'll going over the brassed pieces with a mix of heat, brass brush, oil and steel wool until it gets an acceptable finish. For the next project like this I would like to do a proper gilding though as nothing really has exactly the shine like gold Link to post Share on other sites
Doug Lester 408 Posted February 10 Share Posted February 10 It's really coming along. Anxious to see the completed project. Doug HELP...I'm a twenty year old trapped in the body of an old man!!! Link to post Share on other sites
Bjorn Gylfason 618 Posted February 11 Author Share Posted February 11 This is getting so close to being finished but still so many small things left Today I covered the scabbard with leather after soaking it for about 20 minutes I clamp it and stretch it around the core to see where to trim and punch stitch holes Leather is still such a weird material for me but getting a little better at estimating how much it shrinks when it dries Here it is just stitched up and you can see the bulge at the threads Yesterday I stole a bone from one of my dogs as I needed it to make a tool. One of the marvelous things about forums is all the old knowledge laying around and after seeing Peter Johnsons thread about scabbards and tools I just had to try out making a burnisher with teeth to make the lines along the edges. It works perfectly but Bessi wants his bone back Stitching after burnishing and stretching the leather out. I've started to use this baseball stitch a lot as it is historical and in my eyes the most aesthetically pleasing. Stitch line ended up a bit off centre but at least it is straight And the tooling is simple and made to match the sheath of the dagger he already has I want to leave the blade in the scabbard for a couple of days while it dries to lessen any chance of warping so I'll probably do the chape next 7 Link to post Share on other sites
Alan Longmire 3,878 Posted February 11 Share Posted February 11 Looking great! Poor Bessi, though.... 1 Link to post Share on other sites
Joshua States 2,566 Posted February 13 Share Posted February 13 I am loving this WIP. Great work Bjorn. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Bjorn Gylfason 618 Posted February 13 Author Share Posted February 13 Didn't get much done yesterday. Made a template for the chape and cut it out of brass, folded it and silver brazed it. For the ball I turned one end to slide snugly into the cone and then chucked it into the cordless drill to shape the ball on the belt grinder. Planning to do similar filework on it as the quillons of the crossguard. It is a very simple way to make chapes but oh how much I would like to get some casting equipment to make proper fancy things 3 Link to post Share on other sites
Bjorn Gylfason 618 Posted February 14 Author Share Posted February 14 Yesterday was long but rewarding Finished filing the ball of the chape Then a few hours of final sanding and sharpening the blade. It was getting late but realized just how little there was left so decided to keep going and peened the guard onto the blade I have never liked the idea of using the compression from the grip and pommel to hold everything tight as wood is natural and soft. Oh and my vise in a vise setup to hold the blade Peening Then low tech stropping setup that actually works great for long blades And assembled! And got unusually dry and cloudy weather today to get petter pictures of it. That doesn't improve my photography though it ended up 60 grams heavier than the original and a centimeter longer but I am still overall quite happy with it 12 Link to post Share on other sites
Alan Longmire 3,878 Posted February 14 Share Posted February 14 As you should be, it's beautiful! 1 Link to post Share on other sites
Doug Webster 116 Posted February 14 Share Posted February 14 Excellent! I'm amazed you accomplished this in a mere fortnight. 1 Link to post Share on other sites
Bjorn Gylfason 618 Posted February 14 Author Share Posted February 14 18 minutes ago, Doug Webster said: Excellent! I'm amazed you accomplished this in a mere fortnight. It goes relatively fast when working with singular purpose but still roughly 150-160 hours in it Link to post Share on other sites
Brian Dougherty 1,421 Posted February 14 Share Posted February 14 1 hour ago, Bjorn Gylfason said: It goes relatively fast when working with singular purpose but still roughly 150-160 hours in it That's actually quite impressive. I don't think I could have done that in 10 times as many hours. -Brian Link to post Share on other sites
Francis Gastellu 273 Posted February 17 Share Posted February 17 What a great thread this has been to follow! Thank you so much for taking us with you on the journey. It's a beautiful sword, very well done, sir. Link to post Share on other sites
peter fontenla 100 Posted February 18 Share Posted February 18 Beautiful and didactic work, thanks for sharing! Link to post Share on other sites
Joshua States 2,566 Posted February 19 Share Posted February 19 A truly wonderful project. Thanks for the process photos. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Kevin Colwell 171 Posted February 27 Share Posted February 27 this is a really lovely creation. I have enjoyed watching it. Great work! please visit my website http://www.professorsforge.com/ “Years ago I recognized my kinship with all living things, and I made up my mind that I was not one bit better than the meanest on the earth. I said then and I say now, that while there is a lower class, I am in it; while there is a criminal element, I am of it; while there is a soul in prison, I am not free.” E. V. Debs Link to post Share on other sites
