Eric Estlund 101 Posted March 11 Share Posted March 11 Hi, folks- I've been experimenting with leather over wood core scabbards, and have been struggling with finishing and closing the pointed tip. I can get a decent wrap wet forming, but actually getting a smoothly finished termination has been difficult. I'm wondering if anyone can share their process, or if there are photos of historic examples that could be linked? While I could hide these with a chape, I would prefer to choose that than feel forced into it. Cheers Eric Estlund WinterCutlery.com IG @wintercutlery Link to post Share on other sites
Joshua States 2,470 Posted March 11 Share Posted March 11 What type of leather are you using? “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Eric Estlund 101 Posted March 11 Author Share Posted March 11 (edited) Veg tanned, about 2oz. I should probably try to thin it more in the tip wrap. I've had modest success with relief cuts and wet forming it back over, but that seems less than ideal. Edited March 11 by Eric Estlund Eric Estlund WinterCutlery.com IG @wintercutlery Link to post Share on other sites
Joshua States 2,470 Posted March 11 Share Posted March 11 10 minutes ago, Eric Estlund said: try to thin it more in the tip wrap This. Skiving it thin and ragged edged to hide the seam “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Eric Estlund 101 Posted March 11 Author Share Posted March 11 Do you have any photos of this? Just trying to see if I'm on the right path and need to push further, or rethink how I'm approaching this. Thanks! Eric Estlund WinterCutlery.com IG @wintercutlery Link to post Share on other sites
Eric Estlund 101 Posted April 10 Author Share Posted April 10 (edited) So to answer my own question a bit- today I started at the tip, and did a bit of wet molding to get the leather to wrap and center the seam. Once I knew what material was being used there, I cut a small dart between the parts that would make the seam, folded it back over the nose and cemented it in place. When I started sewing the welt effectively starts by drawing the edges over this tab closing the dart. This saves the little bell or fish tale from things like traditional puukko sheaths. Todays was imperfect, but felt like stepping the the right direction. No idea on the historical accuracy, but then, there are greater anachronisms. Edited April 10 by Eric Estlund Eric Estlund WinterCutlery.com IG @wintercutlery Link to post Share on other sites
Alan Longmire 3,682 Posted April 10 Share Posted April 10 Have you considered not stitching at all? Many leather on wood scabbards were just skived and glued, the same way you do the grip. Link to post Share on other sites
Eric Estlund 101 Posted April 10 Author Share Posted April 10 This was actually the first one I have stitched- the other two cored sword scabbards were glued. Part of it is practice, but I need to improve the joint fit up to be happy with those (I've added cosmetic strips to mask the joint on those). I certainly have no problem using adhesives. The stitching on this one was skill building- I want to be able to choose the best method for each project. On my knife sheaths I typically machine sew as it saves some wear and tear on my hands, but on these I am interested in having a skill base to work from. 1 Eric Estlund WinterCutlery.com IG @wintercutlery Link to post Share on other sites
