Type B viking age sword
Bjorn Gylfason
This is a lot earlier type of sword than I usually do but got a commission to make one with the specific request to use medieval wrought for the hilt
I have figured out that leaving wrought to simmer in citric acid brings out its character amazingly without deeply etching it as that wouldn't have been comfortable to hold.
And as usual every part gets peened in place
He also wanted as dark of a grip as historically plausible which gave me a reason to make some verdigris and play alchemist. Grip is a piece of European valnut and it actually surprised me just how dark it became
At first I thought I was going to be doing pins between the pommel parts bit apparently the type Bs were peened through both parts along with being a lot blockier than for example the type c
Final result was an 80cm long blade at the upper range being 54mm wide at the base and with a very linear distal taper from 5mm at the base to 2mm at the end of the fuller. Point of balance is 16cm from the guard. And a total weight of 1300grams
I have to say I think it feels unwieldy compared to late medieval blades but absolutely scary chopping potential.
It did motivate me to continue my billet making for a pattern welded one though I still haven't decided exactly what type I will be going for with it
  • Like 5
Bjorn, I do like your sword making and WIP posts. I have not done any swords yet.
Might I ask the strength or mix used in the citric acid? How long is the heat?
I like the etch and have tried citrus acid on wrought before but not with these results.
Kind thanks, Gary LT
It's never an exact science with me but mostly done by feel :lol:
I sanded the parts down to 400 grit and then put them in my vinegar bucket for a few hours, scrubbing them a few times with fine wool until they had matted up uniformly
Then mixed about half of this 100% citric acid in roughly 1.5 liters of water and heated to just about starting to boil. It's granulated and meant for cleaning dishwashers
Then put the parts in and let it simmer for about ten minutes or so, fish them up and clean them with a plastic sponge under running water. Rinse and repeat until getting the desired look
Thank you Bjorn! I can get my hands on something similar to this brand citrus acid and I have nice wrought to try. Soon to try on a another project.
Gary LT
Great work as usual.
Could you give some details on making and applying the verdigris?
