Could use some constructive help here
Oberu
Yeah, that handle looks great!
  • 8 months later...
Any advice on peening tangs? This is some high vanadium spring steel and even though I thought I'd kept the tang soft it's harder than woodpecker lips.  I've got a little acetylene torch I could use to heat it up.. thinking I'd wrap the handle in wet rags and try while it's hot.  I've got the handle glued up using some G-flex. Any advise is greatly appreciated!
I managed to pull it off. I used an acetylene torch to gently heat the tang. From there it was all hammering!
I really like the shape of this blade in raw form.
The walnut is beautiful and the carving adds the right touch.
Very well done so far and should and will finish up with class.
Gary LT
