Garry Keown Posted April 13, 2022 Posted April 13, 2022 (edited) Having been asked how I do a long grind on my jigs and in particular the point on the tanto style, this is a thread on my jigs and how I use them. Pic one is the shelf of jigs under my knife templates. The majority of my jigs are similar to this one that has the 10mm flat and angle alloy with a pair of hinges. I set the angle ahead of the base plate and in use set the (stainless steel) work plate on the grinder so the base plate is just ahead of it so any grindings do not get on the work plate and gall the alloy. The cut out on the angle alloy allows for the knife with carbide faced filing jig to the held with small clamp and easliy turned from end to end to do both sides of ther blade. The jigs are set by the bolts with locknut pressing on the bottom plate and the screw up through the bottom plate keeps everything firm in place at that setting. These jigs are adjustable but because I have many knives to do of the same thickness and blade width it is easier to have seperaste jigs for each although for some I am able to note on the template to use a certain jig + or - a certain amount (noted later in the thread. Edited April 13, 2022 by Garry Keown 4 1 Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing.
Garry Keown Posted April 13, 2022 Author Posted April 13, 2022 For the scandi grind that precipitated this thread I have a set jig for the scandi grind originally set for the bush craft knives I offer. It was for the shorter blades knives so was just long enough for them but the longer 12 inch bladed tanto under discussion required the same fix I have for a number of other knives and their respective jigs with extensions suiting multiple jigs With one of the extension screwed to the bottom of the jig I gain sufficient length for the 12 inch blade And with the front extension in place, the file guide on the blade (template in this case.) it is all ready for the pre HT grind. I use 2 clamps to counteract the grinding pressure and having the jig and a 50 grit belt you can get this done fairly quickly. While I am holding this for the pic I still have half the jig length on the grinder work plate so a very stable set up. And by marking the tip angle back along the blade on both sides I can set the blade on the jig to do the tip, measure in from each end of the jig and know that bothe sides of the tip with have the same grind. 3 Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing.
Garry Keown Posted April 13, 2022 Author Posted April 13, 2022 (edited) Should I need to do a longer blade an extension with the file guid cut outs as marked on this one allow for a 20 plus inch blade although I would need a longer plate to secure the handle of the knife so about 5 inches each end past the cut out. Depending on where the jig was originally set I have file marked the dead set position on either a point or a flat on the bolt head. On some templates where the grind is close to an established jig I can mark on the template the letter marked on the jig and plus or minus in increments of 1/8ths so I can quickly set for a similar grind and return it to the "SET" angel quickly and repeatedly. A template may read B + 1/4 or something similar and so any blade can be the same as every one that has gone before and will be the same as every one after it as shown by the four Heavy Hunters on the left here that I am about to finish hand sanding. I grind with 50 grit belt pre HT then with 120 grit folowed by 240 grit and then hand sand so it is only a 15 min hand sand to get them ready for handles. Edited April 13, 2022 by Garry Keown 3 Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing.
Garry Keown Posted April 13, 2022 Author Posted April 13, 2022 (edited) A different jig is this one I have for doing the Bearded chef knives. Without the hinges it is a simpler set up although not as easy to adjust more than a 1/2 turn of the bent armed light bolt without adjusting the tension on the hold screw along the bottom of the front plate. You can see the progression of grinds and grits on the base of the jig where I will grind the first part with a + 1/4 turn on the adjustment handles untill I am at about 30 thou edge thickness the go to set adjustment for the 120 and 240 grit till I am at 10 thou edge and finish with the 240 grit at + 1/4 to fine the edge down further. For this jig and blade shape I have a single screw to hold the blade in place over a stud under the spine and this waay I can grind without clampos in the way. Edited April 13, 2022 by Garry Keown 4 Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing.
Gerhard Gerber Posted April 14, 2022 Posted April 14, 2022 Thanks for taking the time to share all that Garry! 1
Alan Longmire Posted April 14, 2022 Posted April 14, 2022 4 hours ago, Gerhard Gerber said: Thanks for taking the time to share all that Garry! Indeed! This is getting pinned, and may move to Tools and Toolmaking later on. 2 1
Kreg Whitehead Posted April 14, 2022 Posted April 14, 2022 20 hours ago, Garry Keown said: For the scandi grind that precipitated this thread I have a set jig for the scandi grind originally set for the bush craft knives I offer. It was for the shorter blades knives so was just long enough for them but the longer 12 inch bladed tanto under discussion required the same fix I have for a number of other knives and their respective jigs with extensions suiting multiple jigs With one of the extension screwed to the bottom of the jig I gain sufficient length for the 12 inch blade And with the front extension in place, the file guide on the blade (template in this case.) it is all ready for the pre HT grind. I use 2 clamps to counteract the grinding pressure and having the jig and a 50 grit belt you can get this done fairly quickly. While I am holding this for the pic I still have half the jig length on the grinder work plate so a very stable set up. And by marking the tip angle back along the blade on both sides I can set the blade on the jig to do the tip, measure in from each end of the jig and know that bothe sides of the tip with have the same grind. Thanks for the pic. I will have to see if I can do that. If I was going to keep ol griz I would want a larger work rest like you have. I think if I move my work rest back enough to hang the blade down like that....my 2.5" angle iron wont be super stable on it. Pretty kewl set up for sure. I just use a torpedo level and some notes for what to grind things at. 1 1
Raymond Richard Posted April 16, 2022 Posted April 16, 2022 Thought you were talking fishing jigs but this isn't the fishing forum. If Wayne Goddard was still alive he'd get a kick out of seeing this thread. Raymond Richard www.hawknknives.com
