Kreg Whitehead 67 Posted April 19 Share Posted April 19 I am working on this blade made out of some of the concrete blade steel. It cam out of the quench reasonably straight. The next time I will have some kind of fixture set up to clamp the blade in when I take it out of the oil. What's a good angle do ya think I should shoot for here? The blade is a little under 1/8" and right now its ground about 3/8" up the blade. Once upon a time Joel put a post up that was kind of a cheat sheet for if the blade is x amount thick....and the bevel is y amount tall....then the angle =z I could probably use a re fresher course on the lingo......if its 15* a side.....is that 30* inclusive....or do I have it backwards. Does the search function work for topic titles? I think I already asked Joel for this once with one titled something like paging Joel to the white courtesy phone. I had it saved but that was a computer or 2 ago. If there is any constructive criticism to improve this one.....or anything to change on the next one please feel free. I am pretty excite to swing this one. Link to post Share on other sites
Alan Longmire 3,766 Posted April 19 Share Posted April 19 Based on my working machetes (store bought, I add!), that looks about right. Somewhere around here there's pics of the blades with the bevel height and blade thickness... I'll see if I can locate that thread. Link to post Share on other sites
Alan Longmire 3,766 Posted April 19 Share Posted April 19 Found it! Link to post Share on other sites
Kreg Whitehead 67 Posted April 19 Author Share Posted April 19 1 hour ago, Alan Longmire said: Found it! Great!...and thanks!! Link to post Share on other sites
Joël Mercier 708 Posted April 20 Share Posted April 20 Just for the record, I use a triangle calculator. https://www.calculator.net/triangle-calculator.html Not that it's going to much useful if you don't already know what angle your want. Also, I learned that grinding too thin at edge is no good when you hack into dry dead tree knots. My bladesportish knife blade is like a cooked bacon now . I have been extremely hard on it though, because I wanted to know it's limits. I don't think hacking into 2x4 would ever have done such damage. 1 Link to post Share on other sites
